Question about Nintendo Wii Console
I cannot access internet with wii. Error code 51030! Please help!
    Genius:
  • 1,035 Answers
Error Code: 51030 The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
  • If you are getting this error after completing a system update, this is usually because the console resets to using the first connection slot after an update. There are two things you can do:
    • If you know which connection file you were using before, you can select that connection file, then select "Use this connection" to change that to the default. You will need to do this each time they download an update.
    • If you don't know which connection file you are using, or if you would prefer not to update the active connection file each time, try to clear, and then re-create your connection setting in slot one before doing the remaining troubleshooting.
  • Check to see if the router you are using is a known to be incompatible. Click here to view our list. If your router is known to be incompatible, we recommend using a different router if possible.
  • Make sure that the SSID (network name) matches exactly to what you have entered in the Wii console's settings. To verify:
    1. Login to your router's settings (click here and select your router, if available, for information).
    2. Look for the section for SSID (typically in the "wireless settings" area).
    3. After you find the SSID (network name), verify in the manual settings of the Wii console that the SSID appears exactly as listed in the consumer's router. This includes making sure capitalization, spaces, or special characters match exactly.
  • Look up your router, if available, in our list of wireless routers, and check for any special notes that may be necesary to get the connection to work properly.
  • The router may not be assigning an IP address to the Wii console, and a connection using the "Manual Settings" may be necessary. Click here for help.
  • Your router may require a firmware update to work properly with the Wii console. Firmware updates can usually be found on the router manufactruer's website; consult the manufacturer for more information.
Posted on Sep 06, 2010
I try to connect to my netflix & it says i dont have an internet connectiion. it gives me the error code 51030
What you can try is unplugging the modem and waiting a few minutes followed by redoing the connectivity settings. You may need to disable your firewall or change the settings of the firewall to allow theni yendo wii access to the Internet. I hope this helps.
Jun 16, 2011 | Nintendo Wii Console
51030
Sorry to hear you are having problems with your wii. According to Nintendo, error code 51030 is:
"Error Code: 51030
Unable to connect to your wireless network"
Make sure your wireless network is set up correctly with the correct SSID and encryption key. You may also just need to power cycle your router.
For more information, here is the official support article from nintendo for this error:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=lang
Apr 27, 2011 | Nintendo Wii Console
My wii keeps showing 51030 what does that mean and how to fix it to watch movies
error 51030
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=en_US
means that your wii is having trouble connecting to your wireless network.
please make sure that you wireless network signal is in range of the wii
setup your wii with wifi by going to the wii button on the home screen
wii settings> then page 2 select the internet.
go to wireless connection and connection 1 to setup your wifi.
search for access points and input the wireless security password to connect to the wireless network.
if this worked and you still get the error code please power cycle the wii and also check your wireless connection settings and any interference from other wireless networks. you may need to change the channel for the wireless network to 1 or 11.
Mar 28, 2011 | Nintendo Wii Console
Error code for accessing internet 51030
Hello :
Check for interference that may be preventing a successful connection..
Check to see if the router you are using is a known to be incompatible. . If your router is known to be incompatible, we recommend using a different router if possible.
I hope that will help .
rate please !.
Mar 20, 2010 | Nintendo Wii Console
Cant connect my wii get error 51030
This might be handy: http://www.nhotspot.net/wii-error-code-51030/ and http://www.wiierror.com/wii-error-51000.php
Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed.
Verify that the proper Connection File (1, 2, or 3) is selected in the Wii System Settings.
If you have multiple connection files setup, and you have recently received a system update, it is possible that the update has caused the Wii console to select a different Connection File. Click here for step-by-step instructions on viewing your connection settings.
Make sure that your network's name (SSID) matches exactly to what you have entered in the Wii console's settings.
Log in to your router using the default IP (consult the router's owner's manual for assistance).
After you find the SSID (network name), verify in the Internet Settings of your Wii console that the SSID is appearing exactly as listed in your router. This includes making sure capitalization, spaces, or special characters match exactly.
Oct 19, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
184 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
