Question about Proscan 32LA30Q Television
I need to reset my remote for me cable box. Cisco CIS430 I have a sony Bravia TV can you help
I have a Sony Bravia led digital kdl32m4000 tv, I am upgrading my satellite box to hd will I get the signal in hi def. or do I need to upgrade my tv?
No you don't need a new tv. Hook up your HD cable box using HDMI cable. Hdmi out on your cable box then hdmi in on your tv. You need your tv remote to change source input to hdmi.
Jun 10, 2017 | Sony Televison & Video
How to change channel from one to any one channel in sony bravia
I need more info. Are you using antenna connected to RF input or are you using cable box, sat box or ATT Uverse? If connected to antenna . go in menu or Home on Sony. Press setup and look for channel scan. Set to antenna and do auto scan. If cable or other provider box set tv to ch 3 or what ever provider says. You are then using the tuner in that box. You will use providers remote to change channels. Be sure in setup that tv is set to cable if cable box is used. Hope this helps but the info you posted could be more descriptive.
Oct 02, 2013 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
How to control my cable box with the tv control
hello!
refer to your TVs owners manual. You will find codes for common set top boxes there. all the new TV remotes are universal. If you see "cable" or "cbl" button on remote, you will be able to do so. Worst case scenario: you need to buy universal remote or use your cable box's remote to control basic functions on TV. Codes for TVs are included with cable box's remote control. Or, you can call your provider and ask for "Sony Bravia"codes. If you have a satellite box, codes are supplied right inside "setup" menu of the box.
Good luck,
Alex.
Jan 30, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
No sound from my tv speakers. mute is off and exteral speakers are off. There is only TV and cable box on. I can see the volume going up and down, but there is no sound 52 bravia w series
  1. hook up your cable box to another TV check it.
  2. reset the TV by press and hold the [^] on the remote and press [power] on the TV.
  3. Do software update.
  4. replaced the main board,
Apr 26, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Need tv code for my sony bravia lcd tv for comcast remote
For silver comcast on-demand remote with motorola box: Sony 11100, 10000, 11317.
Hope this helps.
Apr 18, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Set up my comcast cisco box to my sony bravia and am getting a "no signal" message even though my cable in and hdmi connections are secured. please advise thx
Hi
Is this a new TV going into an old connection or an old TV going into a new connection? If this is a new connection I would get a hold of Comcast and make sure they have registered the boxes IP address. If this is a new TV then I would go into the menu and select the TV inputs. Go through these until you see an image. If still nothing then the new TV is defective. Good luck
Mar 13, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
Nov 18, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Closed Caption on Sony Bravia
Try a master reset on the TV. With the TV powered on, prss and hold down the up button on the remote (there are 4 buttons grouped together for up down left and right) and while holding down the up button, press the power button on the TV. The unit should power off and then turn back on and ask you to select a language. Let me know if this helps and be sure to rate this solution. Thanks!
Nov 11, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Oct 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Proscan 32LA30Q Television Logo
584 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
