My daughter has an Ipod Nano and the cover popped off and the battery pack had expanded. We were able to get it put back together but now when we try and turn it on or charge it the only thing that happens is an apple blinks on the screen. Any solutions? Can you get another battery for an ipod?
Greetings,
You can get new batteries for iPods but a short in the unit could be causing the problem and you would just be throwing money away. Typically if a rechargeable battery has expanded it may be ready to explode which can badly burn your skin. I would urge you to dispose of the nano as quickly as you can at a place that excepts e-waste. Check here for locations: http://earth911.org/
Good luck
Remove the two screws on the panel on top of the Nano and remove the top panel.
Use a case opener tool to pop the plastic screen cover off the unit.
Slide the screen up to expose the orange ribbon cable on the bottom of the screen that connects to the motherboard.
Unplug the orange ribbon cable from its port and slide the screen out of the Nano.
Fit a new screen in the Nano and plug the ribbon cable into the port.
Replace the screen cover and top panel of the Nano.
hope this helps
