Question about Danby Silhouette DWC512BL Wine Cooler
Fan started making some noise as it struggles to get to full speed. Sometimes, but unpredictably, I can tap the fan and it runs fast, smooth and quiet. Clearly, that is not a long term solution. If anyone knows how to address this problem, I would appreciate your letting me know. The fan part is a Ruilian Science RAL 1225S2 which doesn't appear anywhere on the internet.
  • Anonymous Aug 31, 2015
    after four hours of calls and research the answer is part DG7-2.1. Condensor fan. I have a Heier though when i called them they said the part was a Danby. So i called Danby and they were very helpful matching it up.
I have the exact same problem. Where did you find a replacement case fan as I am struggling to find one. Thanks!
Posted on Dec 26, 2011
I have the same issue I am attempting to replace the fan. It is a 120v .09 amp fan so it shouldn't be difficult to replace. My u it is from a different cooler but the same model of fan. Leads me to think this is a common part and a common problem.
Posted on May 30, 2011
Why doesn't my fan rotate anymore?
definitely sounds mechanical. try prying open the motor area and see if anything happens when you turn it on. i'm guessing it might be a short somewhere that's making the other parts have to compensate
also check into servos, relays, and whatnot
May 15, 2015 | Miscellaneous
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
CPU FAN STUCK ON FULL SPEED.
I think if the CPU run always on full speed and the noise is evident and bothers you ..it means that it has something that force the CPU to run on a higher temperature than normal one ..
This can be the environment or a heat source you use in the room ..or just dust covering the heat dispenser and making necessary for the fan to run faster to compensate .
running the system for long hours and having a high temperature in the room is probably the cause..To avoid damage ..try to clean teh heat dispenser (the aluminum part under the fan )..or at least to remove teh system cover and leave it cool better ..you can also install a second fan and this way assure a better cooling for the CPU ..
Sep 16, 2011 | Acer Aspire X3910-U3012 (PTSED02010) PC...
I have a hp slimline 3100. the cpu fan runs fast everytime i open a program or play a cd. it speeds up the slows down. sometimes it runs really fast, then the computer shuts down. whats going on?
This is an indication of overheating within the PC. Open the PC case and clean all the air vents. Take the heatsink and fan off the CPU and give it them a good clean. Put the heatsink and fan back on to the CPU and start up the PC. check that the fan on the heatsink is running smoothly.
Also, make sure the vents on the power supply are clear and the fan on the power supply runs well.
If you go into the BIOS setup, you may be able to monitor the fan and the CPU temperature.
Mar 18, 2011 | Computers & Internet
Fan makes a whining noise as though it is struggling to turn
Check the bushings for alignment and lubrication. Dried accumulated dirt makes the rotor stuck and hard to turn. If this is the case, remove the oscillation gear assembly at the back of the motor. Lubricate the front and rear bushings while manually turning the fan to loosen it. Do it until the fan smoothly spins. You can use engine oil as lubricant or even cooking oil but don't let it flood the motor assembly.
If the fan smoothly spins when manually turned but still makes a whining noise when plugged and switched on, align the bushings.until desired result is obtained.
Note: These procedures are based on my actual experience and makes a perfect result. Extra effort is the only investment.
Aug 20, 2009 | Schaefer Outfitters Dryers
Heater fan motor
The fan motor can be checked by using jumper wires. remove the wiring connector from the fan.Run the positive wire from the battery to the positive on the fan and the ground to ground. It should turn smoothly and at normal speed at 12 volts.If it is slow and noisy, the bearings making the noise. This indicates the motor is bad.
Nov 20, 2008 | 1997 BMW 328
Outdoor fan motor is not running fast enough?
Check to make sure that you have the correct voltage going to the motor. It sounds like you lost one of your legs of power which would give you 110v instead of 220v. Or it could be in the pc board.
Oct 15, 2008 | Hitachi RAS-09UH Air Conditioner
Cpu fan noisy /chip fan fail
You must buy a new CPU Fan. You can get them HERE or a zillion other places on the Internet. You need a Socket 939 type fan that will handle your cpu speed. If you need help installing it, it may be in the manual. You can read the manual by clicking on the picture of your MB at the top of this post and then scrolling down.
Hope that fixed ya...
Geno
Apr 01, 2008 | ASUS A8N-E Motherboard
Danby Silhouette DWC512BL Wine Cooler Logo
1,052 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
