Question about Garden
My spark plug keeps getting fouled up. I have repaleced it an now it fouls up after running 5 minutes and the motor is puttering and dies. machine is only 1 year old and I no longer have receipt/ help!!
  • 2,100 Answers
A couple of things to check, first the slow speed jet is open too much, needs to be closed down a hair, these are very sensitive so don't move it too much, 1/4 turn at a time. Then the fuel oil mix, might have too much oil, and then the spark plug may need to be hotter, if you can get one. If you can't find one in champion brand, try NGK, they are about the best for 2 stroke engines. Hope this helps.
Posted on Sep 05, 2010
125 Pitbike keeps fouling spark plugs
Hi, Damon and the usual suspects are:
1. Dirty air filter.
2. Fuel mixture too rich or the choke has been left on too long.
3. Faulty spark plug.
4. Incorrect spark plug heat range for the engine type or service.
5. Piston rings badly worn or broken.
6. Valve guides are badly worn and/or seals worn, crushed or have come off the valve guide and are pumping oil through it.
7. Spark plug cable weak or leaking check for spark leakage in the dark.
8. Faulty ignition coil.
9. Low RPM nonaggressive riding style.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Why Does My Dirt Bike Keep Fouling Spark Plugs
Spark Plugs Keep Fouling
http://mypitbike.ru/downloads/ThumpstarServiceManual.pdf
https://www.orionpowersports.com/pit-bike-dirt-bike-parts
http://www.ssrmotorsports.com/store/ownersmanual/pitbike/Pit%20Bike%20Owner's%20Manual.pdf
Sep 13, 2014 | Pit Bike 125cc 4 Stroke Dirt Bike
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
MY 1998 YZ 125 KEEPS FOULING PLUG AND THEN BOGS DOWN
Hi, Anonymous and the usual suspects are:
1. Fuel mixture too rich or enrichner left out too long.
2. Incorrect spark plugs for your kind of service.
3. Piston rings badly worn or broken.
4. Valve guides are badly worn and/or seals worn, crushed or have come off valve guide and pump oil through it.
5. Spark plug cable weak or ignition coil faulty.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Fouling plugs in my yz 125
YAMAHA YZ125 Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 18, 2013 | Yamaha YZ 125 Motorcycles
2007 V Star 1300 spark plugs fouled runs fine at idle but when I try to excelerate it tend to bog down and have to throttle up to keep running. When I bring down to normal coast speed it surges but wo
Hi, Brian and the usual suspects are:
1. Extremely lean fuel mixture.
2. Dirt, rust, water, or ethanol sludge in the fuel system.
3. Sticky throttle cables.
4. Multiple carburetors not in synchronization.
5. TPS sensor out of adjustment or faulty.
6. Wrong spark plugs for the type of service.
7. Throttle bodies not in synchronization (FI)
8. Faulty O2 sensor.
9. Clogged, stuck, or faulty IAC valve.
10. Aftermarket components not compatible with ECM.
For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
Spark Plugs Fact and Fiction Car Craft Magazine
Spark plugs running hot
Yamaha XVS1300A 2007 Service Manual
Yamaha 2007 XVS1300AW Owner Manual
Nov 09, 2012 | 2007 Yamaha V Star 1300
JD X-475 runs terrible after new spark plugs
maybe you have a carb problem and that's why the plug get fouled out
Jul 12, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Why does my 04 yamaha r6 keeps fouling plugs
Still having problems fouled spark plugs
What does fouled spark plug sound like Yamaha R1 Forum YZF R1 Forums
2003 2004 Yamaha YZF R6 Service Manual R6 Moto Data Project
Mar 21, 2012 | 2004 Yamaha YZF-R6
It seems I'm getting too much gas,my plugs are fouled out. The truck runs fine for 5 min when it's cold, then it will foul out if I don't keep giving it gas.
Sounds like your actually not getting enough gas, then your fouling your plugs because something isn't firing right. When your vehicle is cold it uses more gas to run smoother, then when it warms up it is leaning the fuel out and you have to keep giving it gas because it wants to die from not getting enough fuel. Whens the last time you've done a full tune up? or timing adjustment? check easy things first like air filter, plug wires....I'm sorry but I think it's going to be something a bit more difficult, atleast first start with your air filter.
Apr 18, 2011 | 1988 Chevrolet C1500
Why do my spark plugs keep fouling? Car hestitates, putters especially in idle. what else should i check
Hello jonbon742, if you haven't already, change your air filter. 75% of the time when people have the symtoms you do it is caused by the air filter.
Best of luck my friend!
Jan 11, 2011 | 1996 Chrysler Sebring
Failed spark coils on my 1999 Lexus ES 300. Replaced one last March and two more last month. I read that fouled plugs could cause coil failure. Since the recommended schedule for ''hard driving...
exposure to heat, weather,salt in winter and water make them more susceptible to failure I would change them knowing that my others failed
Aug 25, 2009 | 1999 Lexus ES 300
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
