Question about Western Digital (WD3200JS) 320 GB Hard Drive
The drive spins up, and the computer can see it, but I can't access it. Problems with its parameters?
  • stephen_howe Sep 05, 2010
    Thanks for your help. i had a sinking feeling it meant getting the drive recovered, and you just confirmed it.
If you can't access the hard drive at all then the info on the drive is already lost. I would try to boot from your operating system CD and reinstall the Windows operating system. You could have all the information on your hard drive recovered but this would cost more money then it's worth. If the information on your hard drive was not important then reboot the operating system with your restore CD and start it all over. If it won't copy from your operating system CD then you will need to replace the hard drive.
Click on this link below if the information was very important and will need to be recovered:
http://www.nationwidedatarecovery.com/?gclid=CIOw5vW28aMCFR9Ugwodt2MZ2A
Posted on Sep 05, 2010
Works to start with the all of sudden reports parameter problems
Skip Try creating a folder and just copy files. The size of the folder is too big.
Mar 28, 2014 | TDK Electronics - Others
Tip
Network Access After Norton Anti-Virus Install
Sometimes you can't access a WinXP computer after installing Norton Anti-Virus.
There might be a variety of errors at the other computer depending on the operating system.
On the XP computer, in the Event Viewer / System log, there will be the following error:
The server's configuration parameter "irpstacksize" is too small for the server to use a local device.
  1. Start Regedit
  2. Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\lanmanserver\parameters
  3. Edit the IRPStackSize
  4. Give it a value of 15
  5. Reboot the computer
on Sep 20, 2010 | Computers & Internet
Parameter out of normal operating range, computer will not boot up
Probably need to replace the hard drive and reinstall your operating system. Can you boot from a cd? Do a hard drive test and post the results.
Feb 24, 2014 | Microsoft Windows Vista Home Premium with...
"the parameter is not correct" msg re WD My Book, unable to access
Try plugging it into a different computer to see what it does. Sometimes a computer's operating system will recognize an external drive differently if it has only a slight problem, whereas another computer's configuration may treat the problem differently. Some external hardrive software can get jumbled by the programs of a computer or sometimes even their own software programs can cause slight problems. It sounds like a software problem with bugs that can be ironed out. Also some computers will change the drive name to fit into the order of drives it recognizes. Good luck!
Jun 01, 2013 | Western Digital WD My Book Essential...
The parameter is incorrect
yes the one posted in have really helped me out. as I was not sure of retrieving my datas. problems started with encryption and later the word related to parameter. I got really scared. but changing the name of mi drive without formatting it. and then later running chkdsk. I could break into my drive, to get it all. thanks alott
Jul 13, 2012 | Seagate Freeagent Goflex 500 GB USB 2.0...
This error shown when I start open my back-up drive F:/ is not accessible,the parameters is incorrect
Yes it will not allow you to access the back up drive as it is not user accessible, it is accessible only by the system when you try to back up your system by system back up utilities.
Nov 18, 2010 | Computers & Internet
Western Digital External USB 2.0 Drive sometimes won't connect
problems like these are usually because of the usb connections, if the usb connection isnt strong enough i.e getting enough power,
try it on another pc if you can see if the problem persists
Sep 09, 2009 | Western Digital USB 2.0 External Enclosure...
Upgraded 456 gears on my Avalanche now having warning lights on
rubbish
the abs sensors stopped wheels not fast spinning wheels
when there is no signal from the rotor the abs kicks in and releases he brake pressure to that wheel/s allowing them to turn to give the driver steering control
as the abs and traction control use the same wheel sensor , the traction could detect a fast spinning wheel and take action to control it
you have upgraded the final drive ration to 4.56 from standard which will be 3 point something which will make the engine rev higher to get the same speed
and that could be where the problem is coming from as there is a connection between the engine rpms and the road speed and the preset parameters may be not reading the new settings from the new diff ratio
putting on the lights and dropping power
Apr 14, 2017 | 2002 Chevrolet Avalanche
C Drive Access Denied and The Parameter is Incorrect
I found this on a Vista Forum: Re: Access to C Drive
I figured it out -- you have to take ownership of the drive away from
the "TRusted Installer" account, which can be used only by Windows, and
assign it to one of your administrator accounts. AVG did this! So now your C: drive can be accessed by "Trusted Installer" and not you. You are an Administrator so you need to go to permissions and assign the C: drive to you and NOT the "Trusted Installer"
Apr 14, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
How to access a Quantum LM20A011 from A: Startup disk
Hi there check that the drive is found in the bios setting press del. as the computer boots. this will take you to bios you need to check that the HDD is found there first if so then once at a:\ type c:\ then press enter this will access the c:
thanks j
Feb 09, 2008 | Quantum Fireball (LM20A011) 20.5 GB Hard...
Western Digital (WD3200JS) 320 GB Hard Drive Logo
284 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
