Question about Hoover Tempo Widepath Upright Vacuum - Blue
The roller turns strong and the belt is new,but the dirt accu-mulates and doesnt get sucked up! there no observable clogs and the filter side vent blows strong.......ive removed beater,belt and am assuming there may be a problem inside the motor housing as all else appears normal..i was an aviation mech in the military and the above is my assessment........
  • 377 Answers
Are you sure you have the belt on correctly? If it is not, the beater brush will push the dirt, etc, in front of itself and not back to the suction port.
Posted on Sep 06, 2010
Roller that picks up dirt does not move or suck
The roller may be clogged with debris or the drive belt (if there is one) may have broken. The lack of suction could be due to a clogged intake.
Apr 19, 2016 | Dyson DC33 Multi Floor Bagless Upright...
I cleaned out a clog on my dyson and now the brushes will not turn.
Verify that the belt has not slip off. If the belt is on, remove it and verify that the motor spins when turned on. If it does, clean the belt well from any residue (I use alcohol). Also try to spin the roller with the belt off. If it doesn't spin easily, remove it and clean the sides of the roller. Some have bearing and sometimes gets clogged with hairs and dirt. After cleaning, add some oil to the side of the roller and make sure it spins freely. Hopefully your motor is not damaged.
Good luck.
Sep 27, 2010 | Dyson DC15 Animal Bagless Upright Cyclonic...
It stopped picking up dirt . I cleaned the filter, and the belt isn't broke on it. What do i do
Does the belt spin when you turn the vacuum on? There is likely hair wrapped around a brush or roller, or dirt clogged up inside the nozzle somewhere.
Jun 04, 2010 | Dirt Devil M086700 Vision Bagless Upright...
Doesnt ****
If the vacuum sounds like it usually does and still doesn’t pick up, you probably need to replace the belt. To check this, turn the vacuum on and lay it down sideways. Check to see if the roller is spinning. If it's spinning, turn the vacuum off. Stand it up and turn it back on. Do you hear the roller spinning. Some belts stretch over time. If the roller was spinning when the vacuum was on it’s side and stops when the roller has some pressure on it (your carpet), change the belt.
A clogged vacuum cleaner usually sounds "clogged". The noise the vacuum normally makes will seem muffled. First, Unplug Your Vacuum. Then change the vacuum bag or empty the dirt cup. If the bag is filled up more than halfway, this could reduce your suction. Throw out the bag. Look at the area that holds the dirt cup or vacuum bag. Remove any debris. Look for a filter in this area. If you find a filter make sure it's relatively clean. A clogged filter will shorten the life span of your vacuum. Make sure your filter is back in place or replaced, and reinstall the vacuum bag or dirt cup.
A lot of the current style upright vacuum cleaners have attachments and a hose on board. If you have a vacuum hose on your upright, pull it out like your going to vacuum with it. Look at the area you removed the hose from. Remove any debris. I recommend wearing gloves, and try not to use any sharp tools like a needle nose pliers that might puncture your vacuum hose.
For the final step in this vacuum cleaner repair, place the vacuum in a position where you have a birds eye view of the bottom plate. You can usually see if there is any debris that requires removal.
Here is a link that will take you to a site that shows how to access your machine to change belt or look for clogs.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps
Jan 30, 2010 | Hoover U6311-930 Power Drive Bagged...
Vacum not sucking the dirt and the light is not turning on
loss of vaccum brush head not spinning check belt turn over remove bottem plate check belt assmble. remove any string or hair build up sear is the best bet for the belt
Mar 31, 2009 | Kenmore 34923 / 34925 Progressive Bagged...
Kenmore vacuum - no suction, brush wont turn
sounds like the vacuum is clogged and putting too much stain on the agitator, so I would clean out the entire passage way for the vacuum and replace the agitator belt, you must clean out all the hoses it is clogged somewhere
Jan 29, 2009 | Kenmore Vacuums
Dirt devil vaccum #088915 won't pick up.
well the first thing i would look for is if the brushes turn turn it over bump the on off switch if it turns the belt is fine but u might have a clog in the bottom if that the case have to pull cover from thhe bottom take the belt and roller brush off and look up insde where the junk sucks up use a wire hanger if u need and after that clean out where the dirt goes in bag or canister........hope this helps
Dec 16, 2008 | Vacuums
Will not suck
You must still have a clog, check the dirt inlet down by the brush roll(#23) for a clog. Do you have suction at the hose end, if you do, then it is clogged down below. If you don't then either the hose or filters are clogged.
Feb 27, 2008 | Bissell 3576 CleanView II Bagless Upright...
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Hoover Tempo Widepath Upright Vacuum - Blue Logo
152 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
