Question about Philips SA5125/37 MP3 Player
Short battery life
I just started using my go gear and the battery life is quite short. It seems that the display screen is quite bright even after it dims down. I believe that this is chewing up the battery life. The bar for the battery goes down really fast.
  • 8,596 Answers
Get a replacement from Philips if it seems abnormal and you are still under warranty. 8-9 hours is normal battery life for this unit - the product specs are "ideal" - not relaistic. No way to dim this unit.
-tha mp3 doctor
Posted on May 26, 2008
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
Tip
Save your android's battery
1. Dim the Screen: Turn your screen's brightness down to the lowesr setting that you can tolerate. Even if you ignore the next five tips, try this one; it will extend your battery life dramatically.
2. Set screen timeouts to kick in as quickly as possible: To adjust how long your screen stays lit after receiving input, change the appropriate entry in your phone's display setting menu.
3. Turn off Bluetooth and Wi-Fi when not in use:
4. Go easy on power-hungry GPS :
5. Don't use vibrate:
on Aug 10, 2011 | Lands Phones
Buick Rendezvous Head Up Display
not sure about that one but there is a dimmer wheel by the light switch. move it up and down to dim and brighten the dask lights/cluster. wheel may need replacing. also work the lights on and off switch manually to see if there every thing works smooth or hopes from dim to brite.
Feb 16, 2014 | Cars & Trucks
When I unplug the power cord the monitor is bright. How can I keep it bright with the power cord in?
Normally the screen will dim when you UNPLUG the power cord. Is that what you are experiencing?
That is quite normal and is a feature designed to lengthen battery life when the machine is not connected to mains power.
In any case you can adjust the screen brightness. To do this you should be able to use the function keys together with the Fn button. You should find two function keys (along the top of the keyboard) that have symbos like a sun and a Plus sign and a Minus sign on them. Press the Fn key (bottom left on the keyboard probably) and then tap the 'sun +' key to brighten the screen.
Hope this helps. If not, please respond with a comment and I will give further details.
Feb 07, 2011 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
The screen brightness changes due to plug in or battery power
This is quite common actually I see it a lot. There really isn't any reason, it seems that when on batteries it trys to save power by Dimming Down, but it often just mucks up.. I always now set it via the keyboard keys. whenever I change from power adapter, to battery.
Feb 10, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Screen is dark at start up
If its running on batteries the screen brightness will dim quite a bit. If on AC adapter it should be full brightness, but this is adjustable in either case. With the computer up and running, press and hold down the Fn key and push the up arrow to make it brighter and the down arrow to make it dimer.
Sep 16, 2009 | Dell Studio 1537 Laptop
Message to change battery or connect AC
this means that your battery has very little remaining power. If you just charged the battery it means your battery is going bad. Replace the battery.
Aug 26, 2009 | Compaq Presario 2140US Notebook
Dim monitor
I am assuming this is on your laptop display and not a monitor connected. If this is the case, you most likely pressed FN + the DOWN ARROW. You can use the FN key (usually on the left side near CTRL and/or ALT) in combination with the UP and DOWN arrows to increase/decrease the brightness. This is real handy when you want to have longer battery life as the lower the display brightness is the less power it uses.
Hope this helps,
Chris
Mar 23, 2009 | Dell Latitude D600 Notebook
The screen on my Apple Powerbook G4 goes dim and sometimes out.
How long before it goes dim?
Does it start strong, then dims right away?
Feb 27, 2009 | Apple iMac G4 Desktop
Light is dimmed. Cannot make it brighter.
This happened to me, too, when I replaced the battery. Turns out one of the wires that affects the brightness came loose. I found the loose wire, touched it to a few places where I thought it should go, and one of them caused the screen to come on to full bright.
I was extremely nervous dealing with this - never soldered in such tight quarters before, but once I soldered it down, the problem was solved. I have other problems with my ique - like extremely limited battery life - but the brightness problem is solved.
Mar 02, 2008 | Garmin iQue 3600 GPS Receiver
Philips SA5125/37 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
