Question about Kenmore 64802 Top Freezer Refrigerator
The freezer fezzes perfectly bot my refrigerater does not get cold. I cant feel a bit of cold air coming from the top but not much
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 06, 2010
Freezer not cold but refrigerator still cool
HI JULIE.TRY DEFROSTING ALL FIRST 24/48 HOURS.(USE ALTERNATIVES FOR FASTER DEFROSTING.ie;hair dryer;steamer;boiling water bowls etc.)if ok after that great.if same again then 1-defrost timer 2-defrost heater 3- t/stat.good luckALI
Jun 30, 2012 | Maytag MBB1954G Bottom Freezer...
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
My refrigerater temp won't go below 55 degrees. Is there something to try befroe bringing the repair man out? The freezer seems to work fine.
The air door "cold control" may be obstructed or the air return may be obstructed. The air return takes the air from the refrigerator section and delivers it to the coil. It must be clear for the fridge to operate properly. The cold control is just a door flap that opens and closes and allows cold air to enter that part of the cabinet. Open the cold control more and see if that helps. You should feel more cold air coming from it. If you don't then there's an obstruction.
If you have a thermometer that goes below zero, place it in the freezer. It should read 0 to -5 degrees f. If it doesn't then there may be another problem.
Jul 08, 2009 | Sub-Zero 611 / O Bottom Freezer...
Freezer very cold, no air going into fridge it warm ANY SUGESTION
hi there,
check the blower fan inside evaporator,there is fuse on the back side of your refrigerator for cooling fan,check on this using multi tester if busted replace fuse.
Jul 06, 2009 | Maytag 15 cu. ft. / 425 liter Upright...
My fridge freezer comprises of the top one being the fridge and bottom is the freezer. its Zanussi by Electrolux . problem is the fridge is not functioning and its warm (its not cold at all) but freezer is...
It sounds like the fan in your freezer is not working so it can't get the cold air to the frig or your coils are not defrosting and it is stopped u and cant blow air into te frig, One way to check if you hear the fan and know that it is working open the frig and put your hand up near the vent to see if you can fill cold air if you can't now open the freezer door if you can feel the cold air or more air r coils then you could before then your coils are stoped up the unit is not defrosting.
Apr 03, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
My freezer and refrigerater will not get cold
u would have a leak in your sealed system if the fan and compressor are working and still not cold very expensive to fix
Mar 18, 2009 | Frigidaire FRT21H8 Top Freezer...
Heating system
Start with cold engine. Make sure coolant is topped up, leave cap off & run heater while engine running, to be sure all air is bled out of system. Feel hoses going in & out of firewall to heater core. That should be close to same temperature (by feel) . If big difference in temperature to touch, then either a valve in the line is closed or restricted, or heater core may be plugged. Also check if revving engine a bit increases heat temperature at all inside.
Nov 05, 2008 | 1998 Dodge Intrepid
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Kenmore 64802 Top Freezer Refrigerator Logo
75 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
