Question about Philips J44414
Need HELP! Hi, I am so computer retarded, so please bear with me on this. I just got a computer that has Windows ME on it. I was able to get everything downloaded as far as the webcam goes, but I am unable to connect it to any messaging sites. I am not able to get on Yahoo, (who KNOWS why....) so I used this website called its basically a networking site that I can connect to Messanger and not have to download it. ANyway, I am able to see the person I am talking to , but I am UNABLE to connect MY cam so they can see me. What am I doing wrong!!!??? any assistance yall can provide would be great. thanks. Janet
  • King_Eazy1 Aug 14, 2008
    i cant seen anything but a black screen
  • 20 Answers
What does the code p0012 mean
Hi Craig, hope your doing well today. The code you have P0012 means: Camshaft Timing Over-Retarded. It could be the Camshaft Position Actuator on Bank 1 or Computer and even Wiring Related. Without checking it out there is no way of knowing which is the problem. Unless you have a lot of money and just want to try the actuator, I suggest you have it checked out. Hope this helps and have an awesome day Craig!
Jun 03, 2014 | Ford Taurus Cars & Trucks
When I was driving my Honda odyssey 2004 ex last night it started to make a noise under the hood and then the van would not accelerate past 100 km/hr. After a while like 10 minutes later the noise stopped...
you developed a knock in the engine, sounds confusing but your engine computer can't separate bad bearing from pre-ignition, engine knock, to cure this your computer retards the spark, to the max to stop the knock, confuses the computer to the max
Jan 19, 2014 | Cars & Trucks
In cold temp knock when enigine started
The oil level may be fine, but the oil may be too thick, or you could have a worn engine bearing or a weak oil pump.
The engine could have some sludge or dirt blocking a oil port.
Jan 16, 2013 | 2007 Toyota Corolla 1.6
I need the timing for my 2000 chevy cavillier 2.2
Hello mpacovsky: My name is Roger and I will help you. There are no timing specs for your vehicle. Static timing is set when the timing chain is installed. This is the only timing you can do. All advance and retarding is done through the on board computer. The computer controls all of the timing.
Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Sep 08, 2011 | Chevrolet Cavalier Cars & Trucks
When I try to shut down my computer it will just continuously restart. When I disabled the automatically restart thing, it gave methe BSOD with error code 0x0000007e (0xc0000005, 0xba5e25d, 0xba4dbc38,...
Your problem can be caused by a bad memory.Or if you upgraded your memory recently make sure your motherboard can handle the memory you installed last.Some computers require memory to be installed in pairs two 256s or two 512s, try to remove one of them.
Jan 03, 2011 | Microsoft Windows XP Professional
Ml350 replaced a/b cam position sensor reset computer & and erra codes p0016/p0016 check engine ligth is reset car drives with light off when engine is turn off and started the light goes out if you...
P0010....'A' Camshaft Position Actuator Circuit (Bank 1)
P0011....'A' Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0012....'A' Camshaft Position - Timing Over-Retarded (Bank 1)
P0013....'B' Camshaft Position - Actuator Circuit (Bank 1)
P0014....'B' Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0015....'B' Camshaft Position -Timing Over-Retarded (Bank 1)
P0020....'A' Camshaft Position Actuator Circuit (Bank 2)
P0021....'A' Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0022....'A' Camshaft Position - Timing Over-Retarded (Bank 2)
P0023....'B' Camshaft Position - Actuator Circuit (Bank 2)
P0024....'B' Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0025....'B' Camshaft Position - Timing Over-Retarded (Bank 2)
I think your sensors are pattern parts and the readings /resistances are not the same as the original parts ,try some bosch units is my first suggestion ,
Nov 02, 2010 | Mercedes-Benz ML350 Cars & Trucks
I have a 1998 ford escort 1.6 16v zetec but cant set my timing how do i do it? help please! asap!
you can't set timing on that engine. No distributor. Timing is controlled by computer. If it is throwing a timing retarded code, then your timing belt needs replaced because your cam to crank timing is off.
Feb 23, 2010 | 1998 Ford Escort
Windows can't stop your 'Generic volume' device because in use
Two people above are retarded. It's a well known issue that M$ is too lazy to fix. Technically , closing programs that are using files/folders on the usb should work, but 99% of the time it doesnt work. Your best bet is to shut down windows, then unplug the usb device .
Jun 23, 2009 | Western Digital 500GB My Book World...
Philips J44414 Logo
54 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
