Question about Grundfos Plumbing
My CU 301 will not start. No lights on panel but, full power to unit
    Problem Solver:
  • 7 Answers
You panel has bad connection
if you have good hands, open it up and look for the bad fuse or wire.
when the panel is off or cut off you have no option to light it up
Posted on Sep 07, 2010
How can I remove a power steering belt on a 1986 pontiac parisienne
triple posted, but still no engine stated.
cars have 3 or more engine, some 10 world wide, or more.
no country ? USA exports cars. too,.
here is the list , uSA
231 cu in (3.8 L) Buick V6
265 cu in (4.3 L) Pontiac V8
301 cu in (4.9 L) Pontiac V8
305 cu in (5.0 L) Chevrolet V8
350 cu in (5.7 L) Pontiac V8
350 cu in (5.7 L) Oldsmobile Diesel V8
400 cu in (6.6 L) Pontiac listed in wiki 5th generation.
truly sorry
Sig: I must ask questions first, I'm blind, and my tools can't reach, dig?
short answer, loosen the tension device,
i can no point to it , lacking engine, and if it has A/C options.
Jun 21, 2014 | Cars & Trucks
Will not start
Check the door lock and switch, check the input from the switch to the panel. If this is fine then check for power to the panel.remove the panel and reset the connectors to the panel.
If there is no action even after the panel is fixed with the program proceeding further, it is possible that the program controller unit is faulty.
Jan 15, 2013 | Kenmore 3.5 cu. ft. Front Load Electric...
Slow blinking light the same as johnworland on june 13th. A solid light indicates full bucket. I was getting full bucket light the last couple of times I checked the unit. odd because it is set up for...
remove the bucket and check the yop of it for a Float Valve. The float my be stuck in the UP position, If so, jiggle the arm of the float to make it return to the DOWN position.
Jul 13, 2011 | Comfort-Aire BHD-301 Dehumidifier
What does it mean when it says scanner failure?
Hello it means that the scanner bulb temperature is too low or there is some internal or external electrical malfunction.Try these solutions.
1.Check the scanner light.Make a color copy of any document by pressing the Start, Copy, Color button on the product control panel.While the product is making the copy, lift the scanner lid slightly to see if the scanner light is visible.
2.Make sure that the room temperature is suitable for your device
3.Perform a Power Cycle on the unit by following the steps below:
1.Turn the unit off.
2.Unplug the power cord from the unit.
3.Wait 30 seconds, and then re-connect the power cord to the unit.
4.Turn the unit on.
5.Make a color copy by pressing the Start Copy Color button on the control panel.
4.Check the power connections.Disconnect the power cord from any power strips or surge suppressors and then plug it directly into a wall outlet.Try making a color copy by pressing the Start Copy Color button on the product control panel.If the error message displays again, temporarily move the product to a different room, or plug the power cord into a different wall outlet.
5.Perform a partial reset
1.Disconnect the power cord from the product.
2.Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
3.Try making a color copy by pressing the Start Copy Color button on the product control panel.
6.Perform a semi-full reset(Performing a semi-full reset deletes any saved phone numbers on the product).
2.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
If nothing of these works and you still see the error you should take your printer to support service for repairing the parts.
Feb 08, 2010 | HP OfficeJet d145 InkJet Printer
Panasonic NNH965BF microwave starts but immediately shuts off
your mag has gone bad and possible that the inverter board as well, not really worth the hassel
Feb 06, 2010 | Panasonic NNH965BF Microwave Oven
Unit has no power. Replaced both fuses in the
Check power from the supply to the main board. If there is no or low power coming from the supply, then the power supply is bad.
Nov 23, 2009 | Samsung 1.8 Cu. Ft. Over-the-Range...
Dryer control locked light is on and dryer won't start!
Press the Reset Button for 1 minute see if it resets?
or
Are the lights lights DIM on the interface panel ( front of unit with buttons & lights) If so Turn power off to the dryer then you need to remove the top of the dryer lid off and locate the two ribbon cables that go between the CCU and the interface board. as well as two small ribbon cables between the two parts of the interface panel. use a paper clip or screw driver press on the center tab and reset each cable one at a time. Then turn unit back on and try it again.
if none works it could be CCU or Interface panel
Nov 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Forrunner 301 won't turn on or charge
You can try various resets to see if you can get it to respond.
Have you tried plugging the unit into the wall instead of the USB
port.Do you get the Battery Charging message at any time.You can
try a soft reset.Press mode and reset.Then try to power on while
plugged in.A hard reset will delete all your data and settings from
the Forerunner.Press the Power and the Mode button until the unit
comes on and asks if you want to erase all user data.Select Yes.
If the above won't work, try a hard reset that by-passes the
confirmation screen.Press Mode, Reset and Power.
Oct 29, 2009 | Garmin Forerunner 301
M7DH45B2A Dehumidifier
The fall may have knocked out some wiring -- open the unit (remove back panel, then remove front by taking out screws inside) and see if any of the cables to the front panel or control board came out.
Jun 20, 2008 | Maytag M7DH45B2A Dehumidifier
Plumbing Logo
519 people viewed this question
Top Grundfos Plumbing Experts
john h
Andrew Bugbee
Are you a Grundfos Plumbing Expert? Answer questions, earn points and help others
