Question about Moen Home
How do I set the anti scald valve on my shower Model L82691
  • 8,197 Answers
On the link below is the manual. On page 4 step 13 will tell you how to adjust the temp. Please allow time for the manual to load.
http://www.moen.com/shared/pdf/instruction_sheets/ins898d.pdf
Good Luck and please rate 4 thumbs up for the free answer
Posted on Sep 05, 2010
  • 2,100 Answers
This is something that probably can't be done over the fone. You have to have the paperwork in front of you and be able to see it. I know what to do, but couldn't relay it to you so you would understand. The paperwork is important, do you have it? Look up your faucet on the net and see if they have instructions somewhere. Hope this helps.
I have a Glacier Bay shower faucet that is getting increasingly harder to control water temperature out of shower faucet! Water temperature is very hot
check the hot water supply first and if needed adjust if to high and or check your anti scald setting --need to remove the center handle on the mixing valve
How To Adjust Glacier Bay Anti Scald Device Yahoo Video Search Results
Jul 31, 2017 | Glacier Bay Home
We have a problem with our Rinnai 24 hot water service. Hot water goes hot and cold. Does not keep to 38 degrees temperature when showering.
Do You know if there is an anti scald valve in the shower valve? If so it may be scald up with corrosion and need replaced! To see if this could be the problem, flush the toilet next to the shower while the shower is running. If temperature changes in shower I would say that is your problem! If You need to replace it, it would be cheaper to do it yourself! They should be videos on Youtube on how to do it! Good Luck! Regards!
Jul 14, 2017 | Rinnai Water Heaters
Just replaced cartridge in out single handle turn shower handle and now do not get hot enough water. hat could be the problem?
The anti-scald device behind the handle is improperly set. It's the (usually) black ring with 'teeth' on the inside. You obviously misaligned it when during repair. Remove the shower handle, loosen the center stem screw and re-adjust the anti-scald stop device probably ani-clockwise a few notches, then re-tighten the screw and replace the handle.
Oct 22, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Can you adjust hot to cold ratio on moen single handle shower faucet
Pull off the handle and there are limiters located under it. They come set with not enough hot allowed, I have found. It is an anti scalding issue.
Sep 29, 2010 | Moen & Posi-Temp Single Handle Shower Or...
No cold water
Anti Scald Valves have an adjustment under the handle (remove handle) to allow so much hot water in no matter how far handle is turned. Its possible that the adjustment is set to allow only hot water in, this of course defeats the purpose of anti-scalding. Check to see if you can adjust this back. Good Luck have a Great Day. Please give a 4 THUMBS UP if this free answer was of any help.
Apr 01, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
Not enough hot water in the shower even if I turn the handle all
Your valve has an anti-scald feature which automatically adjusts the water temp if cold water is diverted to another location, e.g., a flushed toilet, washing machine filling, etc. Most valves have an adjustment screw to allow you to set the temp. Since each manufacturer is different you'll need the manual or contact the manufacturers support. BTW, these anti-scald valves are being added to building codes in many parts of the U.S.
Mar 07, 2010 | American Standard Cambridge 5' Americast...
How to adjust anti scald valve on american standard shower faucet
Remove the handle,and all the trim rings,and the cartridge cover. take a flat head screwdriver and use it to lift
up the red ring behind everything, this is the hot limit safety stop,
this just stops the handle from turning to full hot.
Once you have the red ring lifted up, notice the numbers and the pointer
on the ring, numbers are on the fixture,
O= hottest 7=cold
See what the ring pointer is set to now, and move it half, before you put this back together, just set the handle on the unit and run the water to see if its to hot or not enough. Once you have found what is the best setting, then replace all covers and trim, handle.
Feb 10, 2010 | American Standard Bath Faucet Ceramix...
My Moen Posi-Temp tub valve runs only very cold or very hot. whats wrong?
Your Moen valve is equiped with an anti-scald device (as part of the valve cartridge) which prevents someone from getting scalded by hot water if there's a sudden demand for cold water, i.e. a toilet flush, washing machine filling, etc. Fortunately Moen stands behind their products and will provide a new cartridge.
Contact Moen and describe your problem.
Jan 26, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Water temperature varies while useing the hot water during a normal shower. jg
Try this before replacing the shower diverter valve.
If this problem is isolated to the shower only, then I would suggest that the shower diverter valve is equipped with an "Anti-scald" safety feature that can not be adjusted, however the temperature regulator/thermostat on the water heater can be adjusted to a lower temperature so as to not activate the the "Anti-scald".
Feb 20, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Home Logo
374 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
