Question about Whirlpool Accubake SF362LXTS Kitchen Range
My door is not licking when i put on self cleaning i'm getting a error with code E1 and F5. why is this happing ?
  • 15,935 Answers
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@$REW
Posted on Oct 01, 2010
What can I do for F5-E1 situation
Check this article as the cause could be the control board, the door lock mechanism or the Membrane Keypad!
Whirlpool Oven Common Problems and Causes
Jan 08, 2015 | Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Why won't the oven door lock to start the self cleaning? The door appears to be shut all the way. After hit start, this code appears E1 F5
According to the Whirlpool website, the self-cleaning latch may be interfering with the door, though this would be indicated by an "E0 F5" error code. If that's the case, Whirlpool recommends the following:
1) Press "Stop/Clear" to clear your display.
2) According to Whirlpool, there should be a door switch plunger in the upper right corner of the oven front. Press and hold this so that the door latch will unlock.
However, if it is indeed "E1 F5" (or any other number with those letters in the code), Whirlpool recommends calling an appliance technician.
http://whirlpool.custhelp.com/app/answers/detail/a_id/319/kw/error%20code
Feb 28, 2011 | Whirlpool Kitchen Ranges
Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning feature
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.FGRT%$^
Jan 15, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
F5 error message and E1 on a whirphool self cleaning range. Oven locked and was wiggle loose and open it. Used it and it was fine, then put on self clean and got the messages and has been beeping since...
Hi there
here the code for you.
F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
This will help you fix your problem and let me know how it goes. Because over time the door latch will ware out and you have to replace it. So i hope this helps you.
Best Regards Richard
Dec 30, 2009 | Kitchen Ranges
Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Feb 10, 2008 | Kitchen Ranges
Kenmore gas range 82772735
Check that door switch is completely closed. Check latch, solenoid, and actuation switch for electrical or mechanical malfunction. One of these is the reason for the E1, F5 code.
Dec 21, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Error code E1 -F5- Broil element comes on and wont shut off
if it is a whirlpool, kitchen aid or kenmore by whirlpool you need to check the self clean latch asembly found on the rear of the unit. check the micro switches with an ohm meter. always remember to unplug the oven before you test any thing or replace parts. not sure why the broil wouldnt shut off. but the f5 error is definatly related to the door latch.
Sep 06, 2007 | Kenmore 95822 / 95824 / 95829 Electric...
Whirlpool Accubake SF362LXTS Kitchen Range Logo
89 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
