Question about Sony FD Trinitron WEGA KD-36FS130 36" TV
20" RCA television
I have no audio because the tv is on MONO and i need to get it on STEREO
    Novelist:
    Scholar:
  • 100 Answers
Greetings de_on,
Per your owners manual I found you should have an option in your Audio menu labeled MTS. You should be able to adjust the MTS by selecting it and press the + key.
There should be three options under MTS: Stereo, Mono, Auto SAP. You would probably want to select Stereo as Auto SAP will engage the Second Audio Programing which will cause other sound problems.
Hope this helps.
Jon
Go Ahead. Use Us.
Posted on May 12, 2008
My rca screen has 'mono' and no audio what should i do
Go to audio settings window, by entering its menu options. Select the option mono to stereo.
Jul 16, 2012 | RCA TruFlat 27F520T 27" TV
I want to connect my XL-DK255 to my TV (Sanyo DP26671). Please help!!!!
http://www.manualowl.com/m/Sanyo/DP26671/Manual/211922
the only way to connect them is audio ...and you can either connect the Tv to the system ..(for better sound ) ..and in this case use the rca (left /right ) to rca (left right ) on the sharp ..if it supports..or ..use a double rca stereo cable ..with a jack 3.5 end ..and insert it in the audio input of teh sharp system ..
The signal from the Tv it will have to be taken from the audio out like in th epage 13 of the manual ..(it has a mono exit ..on rca probably ) and a left and right stereo one ..
If the sharp supports rca stereo in ...use it ..or ...just use the jack (3,5 stereo ) in ...and do not forget to select the proper channel ..
if the sharp system has a TV input channel for sound..on the receiver..use it ..and select the TV to playback the sound ..if it do not ..use the aux.. and selct the aux for control it ..
I do not believe you need to connect it in the other way cause it is not make any sense ..but the procedure is the same ..get audio signal from the system and insert into the audio in of the TV ..it is in the same place and also available mono and stereo ..You will have to select the input in the tv menu..
The cable you need for a stereo connection I think will look like thi s..
http://www.alibaba.com/product-gs/369945799/Factory_direct_supply_Adapter_Cable_jack.html
Jul 20, 2011 | Sharp XL-DK225 Shelf System
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
How can use a set of headphone on my TV? I believe that I can use a RCA connector of some-sort. Can anyone help me?
The exact details of your headphones will matter. If you have a set that gives stereo and connects to your computer, you need a 3.5 mm mini plug (stereo) to RCA (two 1/3" prongs IIRC) adapter. If the headset was for some other devices, the adapter will be a 2.5 mm plug to RCA. (If you have mono headphones, get the mono version of the adapter.) The RCA audio plugs are usually red and white or black for audio.
I hope this helps.
Mar 20, 2010 | Toshiba 32AF43 32" TV
My audio comes out spanish. I have an older 32'' RCA. I don't get audio on most channels and when I do it comes out spanish but the commercials are english. I don't remember doing anything to the tv and...
sounds like the audio of your tv is set for SAP (second audio program). there should be a button on the remote that sais sound. push it and the sound should change from SAP, Mono, and Main or stereo. choose main or stereo.hope that helps
Jul 22, 2009 | RCA Televison & Video
Mono to stereo
You can't convert mono to stereo since the TV only has a single input, and not the separate right and left channel circuits needed for stereo. If you are connecting a stereo source like a DVD player, what you can do is combine the right and left channels into one and connect that to the mono input. You need an audio Y-adapter with two RCA jacks going into a single RCA plug. These are available from Radio Shack. If you are outside the US, there should be local sources such as a stereo shop where you can find the adapter. This won't give you stereo, obviously, but you will have all the sound.
Jun 22, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
How do i Connect RCA VCR to Dynex 20" 480i tv
Ok yellow is always the video signel! and if you have a stereo vcr there should be yellow/red/white the red/ white are audio left and right! if your vcr is in mono then there will only be a yellow/white just use them and let the other red one hang free because it is not needed...if there are other color codes on your model just remember yellow is always the video(picture) the other are for sound and it does not matter where you plug them in at! If you have a black wire just use it in any audio input (red/white)
I hpoes this helps! if you need more help come see us
please rate answer!
Jan 24, 2009 | Dynex 20" Digital TV
No service
  • Make sure that you have connected the cable box properly to the TV.
  • Use the audio and video OUT from the box to the TV IN.
  • Select the correct input on the TV.
  • Connect it using any of the following: A HDMI cable (1 cable for both audio and video), Component Cables (3 RCA's red, green, blue) + RCA audio cables (1 for mono or 2 for stereo), S-Video + RCA audio cables (1 for mono or 2 for stereo), or AV cables - 1 RCA for video (usually marked yellow) + RCA audio cables (1 for mono or 2 for stereo).
  • Consult your TV's owner's manual for detailed instructions or ask me for more information.
Hope this helps. :)
Apr 01, 2008 | Televison & Video
How to connect surround sound system, at the moment its connected through cable, each time we use the dvd player we have take them out of the cable box then into the dvd player, we have a LG 42PC55 tv.
In order of picture and sound quality -- from best to worst:
1. The best way to connect, assuming your TV and A/V Receiver and/or Cable Box have the jacks, is to use a HDMI cable ( this cable is for both sound and video).
2. Use Component Video out to input (3 RCA plugs, Red, Blue & Green) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
3. Use S-Video out to input (1 din plug) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
4. Use Video out to input (1 RCA plug, yellow) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
Be sure to select the correct inputs on your TV and Audio/Video receiver when you are watching TV. For example if you have connected your TV to HDMI 1 and DVD to HDMI 2, you will not see or hear anything if you don't select the correct input on your TV and A/V receiver for the input you want to see and hear.
Detailed connection instructions will be found in your owners' manuals.
Hope this helped you. :)
Mar 30, 2008 | Televison & Video
Using 2 Pc speakers on my Tv
1)probable incompatibility issue--for comparison did you try a set of headphones? 2)The RCA audio outputs on the tv can go to an amplifier that has speakers attached,ie surround sound. 3)Caution==never try to alter vol level at spkr!
Oct 02, 2007 | Toshiba 27DF46 27" TV
Sony FD Trinitron WEGA KD-36FS130 36" TV Logo
150 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
