Question about Toshiba Satellite A60 Notebook
The arrow cursor ( pointer) has stopped in one place as though it has frozen itself there and it you use the touch pad nothing happens what do i do next
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 88 Answers
If it works with a mouse plugged in you might have accidently turned the mouse pad off, use FN key and on mine it's F7 to turn it off and on. hope this works for you
Posted on Sep 05, 2010
Gateway HDMI laptop T series charger output 19 vgets v.hotbut works . burser pointer starts jumping frm place to place on screen dificult to control ?
run it in battery to see if fixes cursor problem
also try a different mouse see if that makes the cursor move correctly
this way you see if its the mouse or power supply
might also a touch pad problem anything that controls the cursor
May 07, 2015 | Gateway Computers & Internet
My Cursor pointer is frozen. The arrow is frozen but if I move the mouse and it blindly finds a tab and I click it that works but no movement of the arrow until I reboot
Does it happen on a specific application or all over your screen? Are you using a special mouse/tracking ball/pointing device? Is this a laptop or a desktop? if you use a USB "simple" mouse does it work. Seems to me like a driver problem.
May 15, 2011 | Computers & Internet
Cursor/mouse freezes
Hi, this Information apply to the same application for the "Mouse" to function properly.
I. “To “Enable” the "Mouse" or (Pointer Device) using the Touch-Pad, go to, Control Panel, click (“Mouse) in the “Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
II. “Highlight”; the item you want to (enable) this being the "Mouse" or “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
III. You may need to “Update Drivers2_bing.gif?” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click “Update Driver2_bing.gif”, click (OK), this will ensure that the application take effect.
Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware.
Hope this Fix it.
Apr 02, 2010 | Computers & Internet
Compaq notebook laptop: my mouse pointer or arrow is
If you have a manual for the notebook, check to see if you can use the function key and the similarly coloured key on the keyboard which enables/disables the touch pad. Usually you can disable the mouse pointer touch pad with this FUNCTION key + MOUSE key when pressed together. Often these keys have the same colour (usually blue). The purpose is to disable the touch pad when you are using an external USB or wireless mouse, then you press the 2 keys again together to enable the touch pad once you have removed the USB/wireless mouse.
If that doesn't work, borrow a USB mouse and attach it to your notebook to use temporarily while you diagnose the problem.
Dec 19, 2009 | Acer Aspire 5100 Notebook
Mouse keeps shifting the cursor to a different place in document
On touchpads if you touch the pad twice in quick succession it acts as a click and the cursor will move to the mouse pointer location. In mouse settings disable "tapping"
Aug 31, 2009 | Acer Aspire 5720 Notebook
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Acer Vista Laptop and cursor nightmare!!
Hi -
I've been having the same problem and it is MAJORLY annoying to be typing along, and have the cursor reappear on another line!
I had a heck of a time finding the place to disable the touchpad, since we use a USB mouse with the laptop. Turns out, someone else helped me find a simple way - hold down the Fn key (next to the left side CNTRL key), and hit F7. That toggles the touchpad off/on easily!
Also suggested by someone else, some mice can cause erratice behavior with Acer laptops, so perhaps try another mouse?
So far, I've been typing this response AFTER disabling the touchpad, and the cursor has not jumped around at all.
Good luck! : )
Dec 10, 2007 | Microsoft Windows Vista Ultimate Edition
Toshiba Satellite A60 Notebook Logo
201 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
