Interference on headset
Yea it started about 2 weeks ago it is now worse than ever it isconnected by usb which puts it beside all the other leads
If i put my hand on the com box it goes away and if i put my hand on the mis it gets worse
    Problem Solver:
  • 17 Answers
I don't know man! You might want to get a new set
Posted on May 12, 2008
Thumping noise while driving left side worse when turning right
have you had it balanced and the driveshaft looked at? id start there
Jun 09, 2012 | 2001 Chevrolet Blazer
Microsoft Lifechat Lx-3000 headset, USB not recognised. I bought the headset a few weeks ago and installed the installation disk. Worked fine for about two weeks until suddenly it will be recognised by my...
In some cases installed drivers become defective for one reason or the other. You may try a free program from Glaysoft called GlayUtilities. Run the program and let it find faults. Clean the system when it finds errors. After the system is clean; reinstall the USB headset drivers and see if that works. That's a Start
Jan 11, 2018 | Microsoft LifeChat™ LX-3000 Headset
I have the same problem with my SONY KF-60WE610
Fan that cools lamp could be Bad,or Lamp could be Failing itself.
Sep 19, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Apparent broken wire issue
I somehow think that it may not be the headphones, but rather the hardware in the computer...but then again if they are under warranty definetely get them fixed(if they are broken?...)
Good Luck!
Jun 12, 2009 | Logitech ClearChat Pro USB Headset
My mic
Logitech headsets do not come with drivers. If this is a wireless headset, it could be that you are receiving interference from other wireless appliances. If you have a wireless phone, this could be the source of your interference. Researching the headset, it does run at a 2.4 Ghz, so make sure your wireless phone isn't on the same frequency, if you have one at all. Also, this is a bluetooth accessory, class 2, meaning you can't be more that 30 feet away from the usb adapter that's plugged into your computer. Also make sure that you don't have a ton of items plugged into your USB ports on you PC, as this can drain some of the power from the USB port and not supply the correct amount to your adapter. You could also try plugging in the usb adapter to a different USB port on your PC, just to make sure the port itself is not faulty. I hope some of this helps.
Dec 27, 2008 | Logitech ClearChat Style Headset Headset
Getting feedback from laptop when no headset plugged in!
go START, All programs, accessories, entertainment, volume control.
Mute rear input.
Nov 24, 2008 | JBL E-System 10 Compact Sound...
Charging
yea same thing happen to me just for the past week at first it just didn't charge & lasted for 10 mins now it won't even flash MOTROLA U ****!!! I WANT REFUND FOR MY H550 Buetooth
Jun 29, 2008 | Motorola Mobility H550 - Bluetooth Headset...
Plantronics Bluetooth Headset P590
This is a "known issue" that I have raised to Plantronics. Whether they do anything about it, remains to be seen. The workaround I have discovered seems to work with both of my P590 headphones that stopped charging:
1. Plug in the USB charging cable to a laptop or computer that is powered on.
2. Connect the USB charging cable to the headphones
3. Connect the 3.5mm headphone cord cable to the headphone output on the laptop of computer (this is the long cable with the normal 3.5mm stereo plug at each end)
4. Plug the other end of the 3.5mm cable into the P590 input.
The headphones should start charging.
Carlos (New Zealand)
Jan 28, 2008 | Radio Communications
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
