Question about Nvidia GeForce FX 5200 Video Card Graphic
Blank screen i installed a fx 5200 pci i disabled my other video card in device mang. and enabled the new one. when i plug the video cable into the new card and restart the computer all i get is a blank screen
  • Anonymous May 13, 2008
    card is on motherboard
  • Anonymous Jun 10, 2008
    when i installed the graphic card drivers and plugged the monitor switch to the graphic card port...i got a blank screen...the problem remains the same even i have disabled the onboard vga display and also choosed the first display as pci slot????????please help me.......
    Problem Solver:
  • 6 Answers
Where's that legacy card? integrated into the mb? if so you'll need to enter bios settings and change it from internal to pci. or at least check to see that the video setting is correct b4 looking at the OS.
Posted on May 13, 2008
Hp pavillion a1632x
According to this page,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00771728&cc=us&dlc=en&lc=en#N83
Unless you added parts, or got a different variation of the computer, the A1632X has two available PCI slots and one available PCI Express x16
I'm the GF FX 5200 only came in AGP and PCI packages, the PCI Express model was label as a 5300.
If you have the PCI version, it should work. If you have the AGP version, there is no slot for it in the A1632X
Feb 23, 2014 | Nvidia GeForce FX 5200 Video Card Graphic
I have a GeFORCE FX 5200 PCI card, and onboard graphics. I had to restore my system, and cannot find the user manual. If it was available online, I'd follow the steps myself, but I'll settle for a quick...
Hi.
You do not necessarily need to disable the built in graphic adapter, the computer can manage two different adapters.
The nVidia should show picture with standard VGA definition (800x600 only) if simply connected to the AGP or PCI slot even if drivers are not installed, and even if built in GPU is not disabled.
If there is no picture, check installation in slot, check that card is not disabled in BIOS, check video cable is well connected, and if nothing works, test the video adapter on different PC, the card may be faulty.
Here the manuals:
Quick Guide to NVIDIA GeForce Desktop Graphics Processors
GeForce FX 5200/5500/5600/5700/5900 Series
GeForce FX 5200/FX 5600/FX 5900 Series
nVidia GeForce FX5200 Gigabyte GV-N52128DS manual - GeForce FX5200 ...
Sep 30, 2010 | Nvidia GeForce FX 5200 Video Card Graphic
If i disable geforce fx 5200 in device manager
Change the vga drivers. To be more specific unistall the drivers, reboot and then install the new ones.
Stelios
Feb 20, 2010 | XFX GeForce FX 5200, Graphic Card
Intermittent stalling in 3D games
sounds like yo had the same Problems that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the monitor cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is running with your card you can also see that from the about nvidia you must have the driver for the card installed to do all this.. hope I helped install the driver first then disable download latest drivers here http://www.nvidia.com/Download/index5.aspx?lang=en-us
Oct 07, 2009 | Nvidia Geforce FX 5200 Graphic Card
Radeon X1300 card displays blank screen at logon
Boot the system in safe mode. Go to device manager and under display adapters , right click on the onbaord graphics adapter and disable the same. It worked on one of the systems i troubleshot for the same problem.
Thanks for using Fixya
Proton
Aug 28, 2009 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
GeForce FX5200 into Sony Vaio Desktop - Disable onboard graphics
Check BIOS settings but first change the supervisor password and log in as administrator. In BIOS there is a option like IGP-PCI and vice-versa. Set it to begin with PCI, save and continue. This what generally what needs to be done when you are not using your inbuilt/integrated graphics thats incorporated in the MB.......sodeep
Mar 24, 2009 | XFX GeForce FX 5200, Graphic Card
Display Problems
enable your onboard graphics and plug your monitor into the onboard. start up your pc and install any needed drivers for the secondary graphics card. right click on your desktop and go to your display properties you should see a faded out screen that has a 2 and a lit screen that has a 1 right click on the faded screen and check enabled then move your monitor cable over to the new vid card right click on the lit 1 and disable it making 2 your primary.
Aug 20, 2008 | Dell Dimension 2350 PC Desktop
Blank Monitor
hey maby the onboard van on it dont work well with yoru pci slow ok so unplug the onbord fan try again ok
Jan 21, 2008 | PNY Verto GeForce FX 5200, Graphic Card
Installing GeForce 5200 on Dell Dimension 2400
I suggest that better check that graphic card in another machine and make sure it is working.
Also find out the data transfer speed of your mother board through the AGP slot is compatible with your graphic card. (e.g. 4X, 8X, etc.)
If you are sure that your system really has an 8X AGP port (A choclate colored slot) then you could deffinitely install the card and work with it.
With the information I received the Dell Dimension 2400 deos not features an AGP 8X port, in that case it is not possible to install the card.
Then you should buy a new motherboard with AGP 8X Port to be able to install the Ge force FX 5200.
Nov 03, 2007 | PNY Verto GeForce FX 5200, (256 MB) PCI...
Nvidia GeForce FX 5200 Video Card Graphic Logo
118 people viewed this question
Top Nvidia Computers & Internet Experts
David
David
Alun Cox
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
