Question about K'nex Toys
Hello I need to separate the bits from the big ball 47045 and the roller coaster 63030. Hence I need a list of parts for each. where can I find this info. boxes have instructions but no lists thank you Noelle
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: I need a instructions for the 63030 roller coaster
You might try calling Customer service at KNEX. We had this problem
a year or so ago and called them. They supplied us with a set.
The number is 1-800-KID-KNEX
Good Luck and have fun!
Posted on Jan 26, 2010
Dyson cinetic big ball beater brush not working
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Sep 05, 2016 | Dyson Cinetic Big Ball Animal Bagless...
Hp laserjet 4250 feeds multiple pages through the manual feed tray
It sounds like the paper pickup roller and separation pad for tray 1 is worn and will need to be replaced. These two parts pickup the paper and weed the pages into the printer. When they get worn down they can grab more than one page at a time. The parts are user replaceable, no need to pay a big repair bill for something like this. The parts come in a kit with rollers and pads for tray 1 and tray 2 along with the instructions and it is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=302
Here is a picture of the roller and separation pad from the service manual.
I hope this helps you out.
Apr 11, 2013 | HP LaserJet 4250dtn Printer
Laserjet 4100 taking in extra paper
Picking up more than one sheet of paper indicates the pickup rollers and separation pad is worn and they will need to be replaced. These parts work together to pickup and separate the paper from the paper tray and when they get slick the rollers allow more than one sheet to enter the printer which causes a paper jam and misfeed errors. The rollers and separation pad come in a kit and is user installable, no need to pay big money for a repair shop to do it for you. The kit RK-4100 is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=259
Mar 28, 2013 | HP LaserJet 4100n Printer
Roller coaster mountain road and rail instructions
roller coaster mountain is one big piece with a small removable castle and removable flag. if you have all these, all you need is the various track. you can look up this set on trackmaster thomas wiki and it will give you a list of the pieces.
Feb 15, 2012 | Tomy Thomas The Tank and Friends Track
Hello, People I have a Tunturi 202 rowing machine, and love-it. However, the little wheels under the seat have worn-through ... weep! Can anyone help me on locating replacement wheels for the...
Good News! Home Depot sells (on-line only) drawer rollers that work PERFECTLY for the Tunturi Rower machine seat rollers. The only difference is the wheels are nylon instead of rubber. Model Number R7228, Internet Number: 100142874. Item description: ROLLER, W/ 1/4" -20 STUD, 1-1/8" NYLON, BALL BEARING. There are two rollers in a package, $5 for two! http://www.homedepot.com/buy/prime-line-1-1-8-in-nylon-ball-bearing-drawer-rollers-2-pack--r-7228.html
Mar 10, 2011 | Exercise & Fitness
Replace bent cv shaft
most shops charge 149.95 including the part but if you want to do this yourself here goes. remove the wheel on the side your replacing. remove the center big nut. (need impact or reall big breaker bar) unbolt the lower ball joint get a big prybar and insert it to where you can push down on the lower control arm. unbolt the tie rod end and smack it a few times to make it dislodge. smack the side of the ball joint with your big hammer a couple times then push down on the lower control arm till the ball joint separates from its stud. then tap on the end of the cv axle and pull out on the wheel assembly till the axle releases from the wheel assembly. using a smaller prybar get on the ground and get behind the big part of the axle near the transmission as you pull you need to pry between the transmission and the axle to get it to pop loose. put a drain pan under the transmission to catch the little bit of fluid that will come out. reinstall in reverse order. good luck
Jan 20, 2011 | 2001 Ford Escort ZX2
Polly pocket roller coaster instructions
pollypocket spash roller coaster set up instructions
Oct 09, 2010 | Toys
I need a instructions for the 63030 roller coaster model
Jan 26, 2010 | K'nex Toys
Corkscrew follies-compatability issues
probably designed for a later win operating system and that causes compatibility problems
Dec 02, 2017 | Hasbro Interactive Roller Coaster Tycoon...
Remove just the front hub?
You're not going to hurt anything. To separate the ball joints you smack the raised spots (nipples) on the actual knuckle/spindle (the big part you're removing that has the bearing) itself near each joint. Just don't hammer up on the ball joint bolts or accidentally hit the rubber ball joint boots with your hammer. You hit it hard and with good aim. Check frequently to see if it has broke loose while you're striking it.
The part you're taking to get the bearing pressed into has to be separated from all of the following: the upper control arm, lower control arm, brake caliper (don't disconnect brake line from caliper, let it rest on something and not hang), ABS sensor wire (if equipped) the axle, outer tie rod end (steering).
If you can't pull out all those little cotter keys you can take a tiny drill bit and drill the holes back out to make room for the new ones.
Oct 03, 2009 | 1996 Honda Civic
Toys Logo
50 people viewed this question
Top K'nex Toys Experts
J.D. Browning
J.D. Browning
Moz Empire
Moz Empire
Level 1 Expert
Are you a K'nex Toy Expert? Answer questions, earn points and help others
