Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
No instructions on lamp replacement for this tv.can you help
  • Panasonic Master
  • 5,387 Answers
With the TV off, unplugged and having cooled down for at least on hour (you can force it to cool faster see the manual), take off the front cover. Grip it from both sides and pull it away from the TV. Loosen the screw that holds the lamp cover and remove the cover. Next loosen the screw that holds the lamp in place. Pull the lamp out slowly by the handle. Handle the new lamp with a cloth to avoid oils and dirt getting on the lamp. Put in the new lamp making sure to properly align it in the TV. Retighten the lamp screw and then put on the cover and tighten its screw. Replace the front cover. If the screws and lamp cover are not correctly positioned, the TV will not work (a protective circuit is involved).
Next reset the lamp time (instructions should have come with the replacement lamp). Wait until the lamp notice disappears from the TV screen. Press and hold the Vol down button on the TV while pressing the Split/Play button on the remote. Hold both buttons until you see a notice that the lamp time was reset (about 4-5 seconds).
For a download version of your manual, see http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC14 .
I hope this helps.
Posted on Sep 05, 2010
Message on screen says lamp needs to be replaced then timer reset. Need lamp and instructions to reset timer
The lamp time reset will be or should be in the owner manual---Google the model number with keywords "lamp install" with the model number and the "manual" with the model number---Google can be a great help.
Nov 01, 2012 | JVC Lamp W/ Housing For Hd-52g786 /...
How much is it to replace the lamp and how do I do it. The red light flashing for lamp means the lamp needs to be replaced for sure?
I'm sorry that the LAMP light flashing. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the TV flashes, it indicates that the lamp of the TV needs to be replaced. Based on the information you have provided, it is the time to replace the lamp with a new one. XL2100 is the replacement lamp for the TV.
The Original Replacement LAMP costs $199 from Sony. Please click hear to order it online.
Please refer page # 16 of the Instruction Manual of the TV to get the instructions to replace the lamp.
Click hear to download the Operating Instructions if you don't have one handy.
I hope the information helpful. Thanks for understanding. Please let me know if you require any additional help/clarifications.
Aug 01, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
FINAL WARNING REPLACE LAMP NOW
All rear projection TVs has a lamp thats like a special bulb inside the TV.
The TV is warning you that this is about to go and will need to be replaced.
This is not a serious problem as TV lamps goes after certains hours of use (normally 4,000 hours sometimes more) and the TV manual should have instructions on how to do this and the part you need.
Contact Sharp support if your TV is still in warranty and for further help :
http://www.sharp.co.uk/pcat/support
if this helps please vote ...thanks and good luck!
Jul 28, 2009 | Sharp 65DR650 65" Rear Projection...
Red and green light flashes then lamp light comes on
If its Sony KF-42SX300 TV then replace lamp in TV,
Lamp replacement procedure is written in instruction manual.
Please buy Sony original lamp for TV safety and avoid aftermarket/ cheaper lamp.
Jul 25, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
May 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Projection lamp nearing end of life replace lamp still coming on
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
Mar 09, 2009 | Sony KDF46E2000 46" Projection HDTV
Where is the lamp housing unit & how do I remove it?
The lamp is in the front of the TV. Pop off the gray cover, about the width of the screen, located just left of the power button. You will then see a bunch of warning labels on the left. Unscrew the one screw that is there and take that piece off. There's your lamp. Unscrew the screw on the right of the lamp and the lamp will slide out.
Nov 05, 2008 | Panasonic PT-50LC14 50" Rear Projection...
How to replace the Sony TV Xl-2100 lamp?
If you have the user's guide, the lamp replacement instructions are on page # 14-16. Click here to download the user's guide if you do not have it.
Good Luck.
Sep 26, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
LAMP REPLACE FOR PANASONIC PT-50DL54 INSTRUCTION
Pull off the panel below the screen.
Remove the two screws hold the 2nd cover from the left.
Remove one screw from the lamp module and pull it out.
Buy the lamp module. It is not worth it to try replacing the lamp. You can damage the bulb easily.
Aug 08, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
338 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
