Question about Indesit W 123 Front Load Washer
I have a Gorenje WA50140 washing machine. Can you help me to find the filter. There is no filter cover on the front of the machine.
Can a clogged filter cause my machine to leak?
Yes. A clogged filter can cause your machine to leak. Always keep filters clean-especially using well water.
Mar 09, 2015 | Gorenje W7543LR Red 600 mm Washer Front...
How do reset for washing machine
I do not see a way to do a reset on this unit. This is the manual and shows what things you can try. Manuals Gorenje UK
Sep 30, 2014 | Gorenje W7543LR Red 600 mm Washer Front...
I have no manuel for my Gorenje WA50140 washing machine and need to know what each Wash Cycle Programme is
Hi Rachel from retired Englishman in SW France,
Methinks the answer is that you could do with a manual for your washer- for now and probably later!
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Aug 01, 2011 | Washing Machines
I have a gorjene wa50140 and it will not drain, or et water into the machine, it stopped half wash and currently full of water, where is the filter situated on the machine as none on the front! I have...
unplug the machine take the back off and locate the water pump it will not be working properly check if there's not a button other debris in it, remove debris and you should be working again eric
Jan 16, 2018 | Washing Machines
Gorenje with error code 7 what is the problem ?????
Error 7 and water inside drum. Sock stucked under tank blocking water to go out. Turn off watter and power, drain washing mashine manually through filter, remove back and bottom cover, remove 2 tube clips from black flexibile thick tube and remove any subject except ball in elbow. You need just screwdriver, muscles and some time. Good luck.
Apr 18, 2011 | Washing Machines
Need Gorenje WA 64153 service manual
Look behind the control panel or inside the cabinet taped to the wall.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2009 | Washing Machines
No manual for Gorenje front loading washer.
Here is a link to the Gorenje website, you can download the manuals from there which explain all the symbols. This link is for the WA50140 machine which I have, just click on the 'manuals' tab
http://www.gorenje.co.uk/laundry/washing_machines?c=161105
Jan 27, 2009 | Washing Machines
Gorenje WA1541 Washing machine
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
And pl rate me if helped.................
Jan 24, 2008 | Washing Machines
Indesit W 123 Front Load Washer Logo
569 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
