Question about Zenith Z50PX2D 50 in. Plasma HDTV
What fixed your TV
What fixed you TV. My TV was doing exactly the same thing and popped yesterday. What did it take to fix yours? If you unplug it for awhile and then power it back up, mine will pop again. I took the back off and did it and it sounds like a capacitor arcing/discharging. It sounds like it is over on the left hand side and on the Y sus board. I have the service manual for this TV now but would love to know what fixed yours. Thanks,
Josh
    Guru:
  • 1,342 Answers
TV automatically turns off. unpluged the tv and
Hey i am having the same exact problem with my same exact tv. If you have already solved your problem I would love to know how u did it. I know you posted this a long time ago but if you havent gotten it fixed yet, if I fix mine i will let you know. Thanks.
Aug 03, 2010 | Toshiba 65H84 65" Rear Projection HDTV
I have a new LG 37" LCD TV. The picture is messing up and I don't know exactly how to describe it, but the people look like they are suddenly cartoon illistrations with not a lot of definition. The people...
Some stores have 30 days return policy you should take it back, and dont try to fix it yourself, then the store has an excuse not to change it. Good luck !
Jan 12, 2010 | LG 37LG30 37 in. LCD HDTV
Will not power up, something popped yesterday, and it lost power and will not come on
The fuse might have blown. Could be various reasons. Unplug the TV. Place the TV down on it screen (on a SOFT FLAT, UN OBTRUSIVE surface). Remove the back panel screws and the panel. There will be a fuse, it is likely blown. Replace it with a fuse of the EXACT SAME amperage (it will be stamped on the fuse [example 5A is a 5 amp fuse]). Replace the back panel and carefully tighten all the screws. Replace your TV on it's stand. Plug it in, and turn it on with the remote. If it works, great. If the fuse blows again, you have a more serious problem. Do not attempt to fix it yourself, it could create a fire hazard. Seek a repair shop.
Sep 29, 2009 | Sanyo DP50747 50 in. Plasma TV
Menu pops up while tv is on
Isolate the problem by removing the batteries from the remote. If the problem goes away replace the remote: "CHEAP" .
If the problem does not go away, the problem is in the TV, repair the TV "EXPENSIVE" !
Aug 28, 2009 | Televison & Video
50" philips won't power on. get the 4x red blink led light
i have fixed 3 of this tv, with that exact problem in the last 2 weeks, needs a power supply, you can try to unplug it again, plug it in, hit the power button, as soon as it turns green, unplug it again, after 15 seconds , plug it back in, if power doesnt turn on by itself, turn it on, if it turns red again, emediatily hit power again, may have to hit power a few times in a row, but most of the time you can get it to come on this way, once it is on, it should run ok, until you turn it back off, but not a fix, needs power board
Jan 10, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
My memorex mltd3222 will turn on for a split second and when the memorex logo comes up, the screen goes out
I don't have a permanent fix, but I do have a work around:
The problem appears to be some sort of "loose connection" associated with either the power plug or how the back of the TV is mounted to the front. Try the power plug first: we unplugged/plugged the plug from the back of the TV (i.e. not the wall) multiple times, jiggling it around a bit each time we plugged it in, and did so until we didn't hear the "pop/click" (i.e. the sound we've come to associate with the problem)... Voila! It started working again.
If that doesn't work, try removing all the screws from the entire back panel, moving the back panel up/off a bit (but completely removing, and being careful not to disturb any of the connections to the DVD player, etc.), and then do the unplug/plug thing. We're guessing that moving the back panel around is essentially facilitating the unplug/plug thing.
Our repairman discovered this when he tried to fix it the first time. He removed the back panel but then the TV immediately started working, so he couldn't determine what the actual problem was. He gave it back to us, and it worked for a few months and then the problem came back. We did the panel/unplug/plug thing and it started working again.
Hope this helps!!
Oct 18, 2008 | Televison & Video
Plugged in, worked, turn on later, did not work
First thing i would do would be to check convergance amp ics
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Toshiba 55H70 55" Rear Projection...
My Memorex DVD Recorder (MVDR 2102) won't open
Power is not turning on
was working until yesterday Jan. 8th 2009
Dec 06, 2007 | Kenwood DV-6050 Multi-disc DVD Player
Akai LCT2716 Flat Panel TV
I HAVE A RED BLINKING LIGHT ON MY TV ANY IDEA'S HOW TO FIX?
Sep 13, 2007 | Akai LCT2716 27 in. LCD Television
Zenith Z50PX2D 50 in. Plasma HDTV Logo
169 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
