Old hard drive new computer
I want to install a hard drive from my old computer into my new computer as a slave drive. The old drive is a Western digial 15.3 GB with a 39 pin connector plus a 4 pin power connector.
The new hard drive in the new computer has a much small pin connecter, plus the same looking 4 pin power conencter.
The new computer is a HP Pavilion a6312p PC.
  • danababy May 12, 2008
    Thanks for your help. We had moved the most important data already via a flash drive. It would have been convienient to have the old drive attacched, but not a problem.
    Thanks Again.
    Dana
I would suggest not even connecting the old drive to this computer. The stats on your new computer are pretty proficient for everyday personal use. I wouldn't use it has a slave drive considering it is pretty small and probably pretty old. You'd have to get some different adaptors to connect your 39 pin drive. Sorry if this isn't what you want to hear. I'm just a college student and this is what I'd do.
Posted on May 12, 2008
What jumpers are for slave Western Digital WD Caviar Blue WD3200AAJS - hard drive - 320 GB - SATA-300 SATA
SATA drives don't need jumpers. Just install the drive and the computer will assign a drive letter.
Jun 06, 2012 | Western Digital WD Caviar Blue WD3200AAJS...
What is the jumper setting for wd200bb 20gb hard drive for slave
Slave - Installing the new drive as the secondary drive:
If installing your new Western Digital hard drive as the secondary drive on the cable with
two IDE devices, move the jumper shunt on the drive to pins 3 and 4. If necessary,
configure the jumper on the other IDE device as Master.
May 04, 2011 | Western Digital Caviar WD200BB 20 GB Hard...
Formatted and installed a WD 60gb hd as slave and is not detected
Did you format this drive to NTFS or FAT32. It may not rcognise it as a slave drive on a format other than NTFS
Apr 11, 2010 | Western Digital Caviar WD600BB 60 GB Hard...
2nd hard drive on Dell Dimension 8300 ( both ATA)
setup the original harddrive as master and the new one as slave then the drive that comes up as c will be the master and the others will follow suit and when you install the games just change it in the install
Jul 20, 2009 | Western Digital Caviar SE16 WD5000AAKB -...
Installing secondary hard drive in a gateway 5310s
in most new cases there are extra slots for extra hard drives, but as long as the ide or sata is hooked up it should work, and you can buy hardware and rig up something ,ive tested many hard drives without hooking up hardware,
the components on the hard drive should not touch other metal
Jul 19, 2009 | Gateway 5310S PC Desktop
Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Apr 06, 2009 | Western Digital Caviar 500GB Internal EIDE...
Computer won't detect new HDD as master when booting
You can do this!
1. Connect your 500gig drive as the slave of your smaller boot drive.
2. Go to http://freewareapp.com/western-digital-data-lifeguard-tools_download/ and get the Western Digital Lifeguard tools.
3. Run the executable to install WD tools.
4. Run that application.
You'll notice there is a Drive to Drive Copy utility. This will clone your new 500gig drive from the smaller drive. When the utility finishes copying the drive, shut down. Remove the smaller drive, and set your 500 gig drive as master/single. Reboot, and you should be running off the new drive.
It is possible that your old drive was an IDE drive and your new one is SATA. If so, you may need to enter Setup on the reboot, go to the Boot menu, and set the boot device to the new drive type.
Mar 02, 2009 | Computers & Internet
External Hard Drive Installation
MAKE IT A MASTER FIRST ..IF NOT THEN MAKE IT A SLAVE.
IF ITS A SATA THE PCB HAS A JUMPER SETTING TO SET IT SLAVE ..MAKE IT A SLAVE FIRST IF ITS SATA
Jul 22, 2008 | Western Digital (WD3200JS) 320 GB Hard...
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
