Question about KitchenAid KEYS750LQ Electric Dryer
Dryer has power but will not run. - KitchenAid KEYS750LQ Electric Dryer
  • KitchenAid Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 10, 2010
Clothes dryer does not work when power turned on at wall. Sounder goes continuously, no lights on panel and panel buttons do nothing
If it didn't do that before removing the capacitor & wires then I would assume it is something you have done wrong. Maybe put a wire back in wrong place. There is a wiring diagram on back of dryer. Motor not starting could be the capacitor, you really need to test it with a capacitor tester. It may also be the motor bearings seizing up. If motor is tight to turn when belt is off then it will be time for a new dryer. Too expensive to replace the motor on such an old dryer.
Jan 03, 2016 | Fisher and Paykel Dryers
Dryer runs and stops and all l.e.d. lights come on
Was the dryer on that the time the power was cut? Was the dryer on when the power was restored?
It sounds as though it may have suffered a surge which may have affected the controller board.
Dec 11, 2013 | Maytag Dryers
Lg dryer dle5001w keeps running
Hay Donald , sounds like the relay on your control board is stuck closed .replace control board, good luck APPLIANCES R EN
Feb 28, 2013 | LG DLE5001W Dryer
My Kenmore Dryer will not start. We replaced the Receptacle but it still will not start.
Make sure the dryer is getting power by checking the breakers. The dryer usually has a drum lamp that turns on only when the door is open. Power is indeed getting power if the lamp turns on. If not, either the lamp is busted, the door switch is not working, or the dryer is not getting power at all.
The problem is likely a blown thermal fuse if the dryer is getting power. This thermal fuse is wired in series with the motor and if it blows, power to the motor is terminated and the motor cannot run. No dryer function works when the motor cannot run. Click on the link below for the detailed procedure in checking for such condition.
Troubleshooting Not Starting Whirlpool and Kenmore Dryers
Feb 11, 2011 | Kenmore Dryers
The dryer won't run and no power when you press the power button but the lights inside will turn on when you open the door what is the problem to it?
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 16, 2011 | LG DLE7177 Dryer
Dryer just quit running. power cord was replaced
If you have a fuse box in your house I would check the fuses for the dryer. The dryer runs on Two 30amp fuses.
If your house is on breakers. Shut the breaker off for the dryer and turn back on and test.
Hope this helps
Dec 31, 2009 | Dryers
Dryer running but not heating. How do I check heating element?
Check the following to address this non heating issue
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 02, 2009 | Whirlpool Dryers
Dryer heating element
There is a fuse in the dryer for the heat.
Before tearing into the dryer, make sure the power getting to the dryer is absolutely correct. (check power with the dryer running) Even with incorrect power to the dryer. the drum will still turn but there will be no heat.
Many a person has paid for expensive service calls for the problem you are having only to discover by the servicer that there was nothing wrong with the dryer but had bad power to the dryer......
Jun 15, 2008 | Whirlpool Dryers
No power???
Try the thermal fuse. Its a white part with 2 wires on top and it is on the blower housing. Some are oval shapped and some are a narrow rectangle. Unplug the dryer and remove one wire and check for continuity with a ohm meter. On electric dryers if this part is blown the dryer will not run. On gas modeld it will run but no heat.
Jul 07, 2007 | Kenmore 83142 Electric Dryer
KitchenAid KEYS750LQ Electric Dryer Logo
62 people viewed this question
Top KitchenAid Dryers Experts
Tim Whalen
Oloyede Monsuru
Virgil Watts
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
