Question about Pool & Spa
Water is pouring out the bottom vent of the lay z spa heater have taken apart but cannot find where the water is coming from it only seems to do this when the pump is on
  • 331 Answers
It is possibly coming from the heat exchanger. Most heaters have a copper tube style exchanger, capped at each end by plastic or metal headers. If the tubing has been subjected to any corrosive water condition such as low PH, low calcium hardness or very high cyanuric acid levels, the tubing may have deteriorated and is leaking. You may have dismantle the heater further and check for leaking.
Posted on Sep 10, 2010
Black water pours out of the heater system into intex spa
Backwash filter system, change filter media if over two years old, flush out heater. Check water clarity going into the filter system, if dirty..., you may have a broken underground line. Check water clarity coming out of filter system, if dirty.., backwash again and check filter media. Also, Heater boiler headers may be rotting.
Apr 10, 2016 | Intex Pool & Spa
My spa throws the breaker at the house when the heater kicks on
For whatever reason, looks like water has gotten in to the heater or heater controls. To prevent a fire, this must be taken apart and repaired. Be blessed.
Feb 25, 2014 | Toys
Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Apr 27, 2011 | Pool & Spa
Water is pouring out of the side of our boiler in the pump room
More than likely, this would the result of the heat exchanger being corroded (rusted) and having a hole in it. Depending on the model of heater that you have (you did not specify in your question) this exchanger may be replaced, but for the most part, due to the cost of the replacement, it may be best to replace the heater altogether.
There is not a whole lot in a heater that would cause water to pour out. Most older units deteriorate over time due to chemical damage and the exchanger just falls apart.
Try opening the cabinet (make sure that the heater is off) and seeing if you can visually see where the water is coming from and the presence of any rust.
If you provide some additional information about the heater, (make, model, and size) it might be possible to further troubleshoot this unit with you.
Dec 29, 2010 | Pool & Spa
I can hear water sloshing around in the drivers side door
If the sound seems like its in the door but is actually coming from the air vents near the door it may be a faulty heater core.
Dec 21, 2010 | 2006 Chevrolet Monte Carlo
Water builup in bottom of fridge
If the problem is in the fridge 1: it could be moisture being drawn from unwrapped vegetables. 2: if you have a "wet wall" fridge check no food wrapping is touching the wet wall.
Mar 21, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Lay z spa water pump is faulty where can I get a
Hi Im Chris From BVL Elecric,
I cover Bournemouth and surrounding areas and supply solutions to most home electrical problems.
A lovely lady customer called me out today to diagnose faulty
LAY-Z-SPA
pump/heater that kept tripping the RCD.
After scouring the net and finding this same problem over and over again but no solution,I decided to get personal with the blighter!!!
RESULT:- problem solved,
Customer very happy,
no new parts fitted,
water heating fine now.
If you live in my coverage area,have a LAY-Z-SPA that is faulty,no or limited warranty then give me a ring and I will be only to happy to come on over and fix it for a small fee.
just think that dead spa/pool heater/pump could be heating your water again tomorrow and there is plenty of summer left to enjoy it.
You can find my details quite easily , just google BVL Electric Bournemouth
Dec 27, 2009 | Pool & Spa
My heater also knocks when starting
Inside the exchanger is a medal vent which passes the water into the heating area. It sometimes comes loose. Weld it back in place.
Fixed!!
If you continue to use it as is the vent will make a hole in the bottom of the exchanger and you'll pay 350 to replace it.
Neal
Aug 01, 2009 | Hayward 100,000 Btu Heater For Ag Pool And...
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Pool & Spa Logo
246 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
