Question about Gearbox Toys Volunteer Fire Truck #2 Pedal Car
Hi - I have a Gearbox Pedal Car- Vol Fire Dept. It is missing the bell. Where can I get a bell? Thanks! kuglarb@netscape.com
Try 1-800-268-5093
empire toys and gearbox toys
Posted on Dec 07, 2010
Clutch on 1994 Ford laser not working. Car has been sitting in garage for 12 months. What do I need to look for?
Does the car have a cable clutch or hydraulic? If cable, there will be a rather hefty cable leading from the firewall (engine side) to the bell housing. If hydraulic, there will be a second fluid reservoir next to the brake fluid reservoir, engine compartment.
Hydraulic clutch: check for fluid level. If low, check for fluid leaks at the servo cylinder, that is the cylinder that operates the release fork on the bell housing, check for fluid leaks from the main cylinder. If it leaks, it will leak inside the car where the clutch pedal rod connects to the main cylinder. Any leaks you find on the main or servo can be repaired with a kit from your spares dealer.
If cable clutch - Check your pedal. If it is low, the cable can be adjusted to take up the slack. On older vehicles, I have found that the firewall itself sometimes corrodes if the cable is anywhere near the battery, and then adjustment does not help. The firewall has to be reinforced first.
If the clutch pedal feels good, have someone work the pedal while you have a look underneath at the release lever (or in the engine compartment if front wheel drive). See if it works well.
As a last resort, the friction plate or pressure plate could be worn, and this will mean removing the gearbox if your car is rear wheel drive. On most front wheel drive cars the clutch / pressure plate can be replaced while the gearbox is in place, a 45 minute job.
Apr 03, 2015 | Ford Laser Cars & Trucks
How to remove clutch master cylinder at gearbox
the clutch master cylinder is on the fire wall at the pedal. The slave cylinder is on the gear box bell housing and in some cars it is now inside the bell housing which necessitates the gearbox removal to replace it.. Removal of an external cylinder is to loosen the hose fitting ,unbolt the slave cylinder and then un-csrew the cylinder off the hose
Jan 06, 2015 | Cars & Trucks
Just bought the KL pedal fire engine. Fire bell hood ornament is missing from package. Also, It looks like the seat/ladder assembly is too close to the dash to be able to climb into it.
If you are not happy with it, then return it and get another one. There is always ways to make adjustments but if it was missing components and they are telling you they dont have them. Get one that is Complete....
Mar 03, 2014 | Kids Deluxe Fire Truck Pedal Car Red
I just bought Volunteer Fire Truck # 1 at a yard sale in perfect condition.it is missing the ladders and I would like to purchase them.
Company is out of business. Similar fire truck recalled in 2002 for lead paint hazard. See:
http://www.cpsc.gov/cpscpub/prerel/prhtml02/02104.html
Not sure if your model has lead paint. You should have it tested.
Jun 19, 2011 | Gearbox Toys Volunteer Fire Truck #2 Pedal...
Hi, car Is a 1995 manual gear box, Subaru Legacy GT Estate car, petrol r/h drive (UK), 2L twin turbo that was imported into UK. clutch pedal began to stick in the pressed down position occasionally so I...
Hi these clutches are actually hyraulic so first id check the oil in the clutch bowl container under the bonnet on the drivers side if you havent already, secondly you can adjust the clutch slightly under the inside of car on the pedal it has a nut you remove then just turn the thread to suit you cant miss it really, however i would be more inclined to think your problem is the clutch slave cylinder on the side of gearbox it would cause this problem when worn as oil leaks past. To locate it just look on passenger side of gearbox and follow the hydraulic hose, they are easy to replace (just unbolt) and not too expensive.
Apr 11, 2011 | 1995 Subaru Legacy
I always had netscape had my computer fixed .now netscape has been removed i also have bell sympatico i want to have netscape back my email address is kriscutmore@netscape.ca
if you have a subscription with netscape or a subscription to an ISP that uses netscape, you can use the CD software installer that came with your package or you can request a copy of the installer from your ISP...
Nov 03, 2009 | Computers & Internet
Frequency numbers for bell county
For a copmprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Sep 26, 2009 | Uniden BC340CRS Base Scanner
Software and/or driver for BH725
I think you stumbled onto a tough problem. I did a little research on Google and it looks like Bell and Howell was split up and various companies picked up the pieces. I think Kodak got the camera division in 2001 (but I'm not sure). If they did you might try contacting their support dept.
Sep 12, 2005 | Bell & Howell BH-725 Digital Camera
Gearbox Toys Volunteer Fire Truck #2 Pedal Car Logo
377 people viewed this question
Top Gearbox Toys Toys Experts
ray gallant
Are you a Gearbox Toys Toy Expert? Answer questions, earn points and help others
