Question about Mitsubishi VS-50607 50" Rear Projection Television
Mitsubishi vs-6047 60 in
Mitsubishi vs-6047 sound works but all3 projectors have no light
Pull the front panel off, remove the 4 screws holding the inner panel on , then with a screwdriver gently touch the wires leading to each of the the projector bulbs one of these is not getting a good connection , it is the one that has about 6 wires leading from it
Posted on Sep 02, 2008
Mitsubishi vs-50707
see a tech you need one they will come and take the panel off and thake the light box with them because you have a circiut problem
Feb 25, 2010 | Mitsubishi VS-50607 50" Rear Projection...
My tv is showing blue when i turn it on i think my blue projector light is out?
i have a mitsubishi vs-60111 when i watch the tv as of last week the color is pale like green color or green,gray color the picture is sharp yet , i took front cover off the lights are still bright red , green and blue what can be the problem / joe
Nov 06, 2009 | Mitsubishi VS-60111 60" Rear Projection...
52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Mar 29, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Mitsubishi VS-5071 rear projection turns on, has audio but no video
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Bill
Sep 10, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Video
What kind of input are you using
Nov 05, 2017 | Mitsubishi VS-5043 50" Rear Projection...
My screen is turning colors
May it have been knocked about so the projectors are out of alignment, or may it have been standing next to a powerfull magnetic field?
It may also sound like a mirror may have become misaligned, since the top half is affected
Nov 07, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Tube sparks inside itself under red projector??
have a tech check your set high voltage is escaping.good luck.
Apr 15, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Please help
If its a rear projection TV. It sounds like the Lamp is shot on the projector, or is going. Look in the back and see if it is lit if it is flickering I would definitely suggest replacing it. If that doesnt repair it then I would ultimately suggest the optical engine which is the projector of the TV
Jan 30, 2007 | Mitsubishi VS-5075 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
