Question about Xerox WorkCentre XD125F All-In-One Laser Printer
After turn it on, the display Shows "H", "4" alternatively, and the XD125f machine does not work. No pre-heating. What is wrong? Thanks a lot for your help! Steven
  • 1,110 Answers
To reset the H4 condition on your XD125F series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
Good Luck and Thank You for using Fixya.
Posted on Sep 05, 2010
Aquarius wf620p. indicator shows test. phonecall to service dept says it is stuck in demo mode and hold down buttons until it clears - it doesn't work
(following pre-typed- No, I cannot type that fast!)
Here are the instructions to clear the 'test' depending on the date code:-
Date code 39 March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39 March 2005 to date code 42 June 2005
Press the cancel button and the machine should return to norma
l
Date code 43 July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 19, 2011 | Hotpoint Washing Machines
Getting J2 on the screen copier won't work
That means the drum cartridge has reached the end of its life.
You can replace the drum unit or the chip on back.
You can google a business called "the parts drop."
They should have both.
Jan 19, 2010 | Xerox WorkCentre XD125F All-In-One Laser...
I have a Xerox XD125F Workcentre. The J2 toner
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
Jul 24, 2009 | Xerox Office Equipment & Supplies
Door on digital oven display
There are two door switches the primary and secondary interlock switch. HEre is the cabinet break down.
Diagram #51 and then Page 7 on this page
Hope this works for you
Feb 14, 2009 | Whirlpool RF368 Electric Kitchen Range
Shows l 6 on screen
An L6 is related to the laser polygon motor. Either the laser unit is bad or the main processor. You can try and take the back cover off and resetting the connectors on the circuit board. But most likely it is the laser.
You can google "the parts drop" to find out prices on those.
It is a lot of work to replace a laser in that product.
Jan 24, 2009 | Xerox WorkCentre XD125F All-In-One Laser...
Frigidaire Range - Oven does not work
If your ignitor looks real dull orange then that is what is wrong. It needs to be bright as the sun or it is weak.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2008 | Frigidaire GLGF386DC Stainless Steel Gas...
Envolope Printing
The XD100 has a manual feed on the right side of the device. You can slide the guides to fit the envelope. Use the envelope printing in your program and I believe you need to specify the size of the envelope in the driver. I think you want to feed the envelope face down (side to be printed down) to have it print on the correct side, but I could be wrong. One way to check of course, try it one way and if it prints on the wrong side, flip it over. There may be an image on the feed slot that shows which side to use.
Jun 24, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
JENN-AIR MODEL D156B Electric oven
code f 0 means what?
Feb 11, 2008 | Cooktops
Printing does not work on Xerox Workcenter XD125F
Does the printer show up when you unplug it from the USB port and plug it back in? Does it say New Hardware or Printer found?
Does it print from a parallel port or does your computer have one?
Unlikely the cable since I have used those on that product before.
If it will print from a computer parallel to parallel, I would suspect the cable obviously.
You can take the back off the printer and reseat the board, and connectors.
What happens when you popo the printer itself?
Jan 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Printer problen
Low Fuser Temperature. Probably a blown heat lamp try reseting the H code Press CLEAR, EXPOSURE MODE, CLEAR, EXPOSURE MODE. The display should go blank. Then enter 14 with the copy count keys and press START. If the machine does not turn off and back on by itself - then turn it Off and back on. See if the H code comes back. Tim
Jan 28, 2007 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
