Question about Toshiba Satellite M115-S1061 Notebook
Toshiba satellite network card
I was trying to create a local (home) network to be able to share files and printers. It seems that whatever i did, i somehow made it impossible for me to now connect to the internet and I think that my internal network card is off.
  • Toshiba Master
  • 6,487 Answers
Check first if the network adapter of the pc is disable:
Right Mycomputer>Properties>hardware>device manager>network adapter if your adapter is disable just right click on it and click enable.
For file and printer go to this link:
Posted on May 12, 2008
How to use comupter as sever
Proxy server
Use a Computer as a Proxy Server
Small networks can still take advantage of a proxy server.
The Microsoft Windows operating system allows you to turn your computer into a proxy server.
A proxy server is a central computer on the network connected to the Internet.
Other computers on the network use the machine to connect to the Internet.
The Internet Connection Sharing (ICS) configurations on the machine allow you to turn your computer into a proxy server.
Click the Windows "Start" button and select "Control Panel."
Double-click "Network and Internet Connections."
Double-click "Network Connections" to view a list of network card settings.
Right-click your network card icon and select "Properties."
For most users, this icon is labeled "Local Network."
Click the "Advanced" tab.
Check the box named "Allow other network users to connect through this computer's Internet connection" in the section labeled "Internet Connection Sharing."
A warning message pops up telling you that your IP is reset for the proxy computer.
Click "OK."
Reboot your computer for the settings to take effect.
You also need to reboot each client machine on the network to ensure they see the proxy server.
Turn a Computer Into a Server
When you have more than several computers and users who want to share files and resources, whether in your home or in a small office, you can convert a computer into a server.
Building a server out of a computer will allow users to access files whichever computer they use to access them.
An example of the resources that can be shared is a printer and shared folders such as photos and documents. Here's how to convert a computer into a server.
Prepare your computer.
Clean up the computer with unnecessary files to save on space.
If your computer is really old, install the latest operating software so that it is compatible with the rest of the computers that will share its resources.
For this example, we are installing Windows XP.
Check the hard drive space or capacity if you have enough.
You can do away with 256MB sized old computer, but you may want to think about adding more disk space for future needs.
You can easily buy extra internal or external hard drives to bump up your disk space to a capacity that you would desire.
Try purchasing a 10GB extra disk drive then insert it in computer or connect via a serial port or USB hub it if it is external drive.
To install the hard drive driver on XP, let the hardware wizard run you through the options.
You can install the driver with the installation CD software that your hard drive came with.
Follow the options during installation. ,
Check your computer if the network card (ethernet card) is functioning properly. if it does not, you would need to install a NIC or Network Interface Card.
Some old computers have 10 megabit cards, but if you want to have high network performance and better connectivity through your LAN (Local Area Network) then you would need to upgrade your NIC by installing a 100 megabit or 10 gigabit NIC.
Install your network card driver using the installation CD that came with it then follow the installation wizard.
Get a network router. Connect this router to your high speed connection.
The most common ones to use are Netgear, Linksys or DLink routers.
Choose a wireless router so that if you have wireless users they can connect easily (plus this will save you on trying to connect cables to the router all over the place).
Set up your network connections.
Click on "Start," "Control Panel and "Network and Internet Connections."
Pick a task from the options listed or pick a control panel icon, in this case "Network Connections."
If you are set up to pick up the IP Address of your computer automatically, one you have installed your NIC in Step 4 and rebooted, it will pick up the connections automatically whether plugs in using a LAN or network cable or using wireless card.
Rename your computer. Name it so that it can easily be identifiable in your network.
You can either name it simply "SERVER" to be easily recognized, but it is all up to you how you want to name your server.
To name your server if you are using Windows XP, you can right-click on "My Computer" then click on "Properties."
Go to "Computer Name" tab then click on "Change."
Other Windows operating systems or versions would have this feature located somewhere else. Read the owner's manual that your computer came with it.
Create a shared folder by going to "My Computer" and "C:\Documents and Settings\All Users\Documents."
Create a new folder by right-clicking on the screen, then click on "New Folder."
Name the new folder "Shared Files" or anything that can easily be identifiable.
Take note that on Windows XP, any folder that you create and then dragged into the "Shared Documents" folder will be automatically shared by everyone.
You can restrict certain folders by dragging the folder out of the "Shared Documents" folder, then right-clicking on the file folder, clicking on "Properties," then the "Sharing" tab and finally "Make this Folder Private."
Create a shared resource by adding a printer or fax to use. Go to "Start."
Click on "Printers and Faxes" and "Add a Printer," then let the installation wizard that came with the printer or fax guide you.
Name your printer or fax (for example, "Shared Printer").
Then once the printer is installed, set it up so that you can share it by right-clicking on the "Shared Printer," then on "Properties," "Sharing" tab and finally on "Share this printer."
Connect any computer to your server.
Go to each computer and ensure they are connected on the same router.
Then go to "Start" and "Run," type in "EXPLORER," then on the menu click on "Tools" and "Map Network Drive."
A window will pop open where you will assign a "Drive" letter and a "Folder."
Choose any driver letter, for example "G" to denote "Group" drive or "S" to denote "Shared Drive," then type in the IP address of the server.
To do this, go to the server, then go to "Start" and "Run," type in "CMD" then type in "IPCONFIG." This will display your server's IP address.
Type the IP address on the "Folder" field on the computer.
You can also try if the computer will automatically find it by choosing the drive letter then clicking on the "Browse" button on the "Folder" field.
Start using the shared resources by going to the drive letter that has been assigned on your computer.
Sep 24, 2013 | Computers & Internet
Toshiba a505 laptop won't print on shared home network
make sure printer is shared on nerwork and install print drivers on your laptop
Jan 09, 2010 | Toshiba Satellite A505-S6975 Notebook
I have a Toshiba A105-S4364 laptop that will not connect to my new Epson wireless computer. The laptop sees the printer but refuses to print. Do you have any suggestions?
check see if File and printer sharing is turned on
Windows 7
START>Control panel>(click on view to small items view)Network sharing centre>in the top left corner you will see an option CHANGE ADVANCE SHARING SETTINGS>in the list you will see TURN ON FILE AND PRINTER SETTINGS
Nov 09, 2009 | Toshiba Satellite A105-S4364...
DI-524 router printer sharing
All you have to do is that you will have to setup your Hp to share or to be seen by other machine on the network by going to the network properties then setting the network, file and folder on your hp to be seen and shared by other machine.
Sep 21, 2009 | D-Link AirPlus DI-524 Wireless Router
Windows Vista
In the start menu click network,on the bar on top click network and sharing center,scroll down and enable network discovery.
Apr 20, 2009 | Microsoft Windows Vista Ultimate Edition
1800HG ROuter + Home Network
Rather than try and explain how to set things up here (would be a rather long answer!)... follow the links below ;)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Go here for instructions on setting up printer sharing
go here to setup file sharing
Aug 30, 2008 | 2wire 1800HG Router (RG1800HG00)
Setting up a new computer on a wireless network
hello Danj29,
I suggest you make sure that your Vista is configured to connect to a private network. To do this follow these steps:
1. Click Start, right-click Network, click Properties.
-The Network Sharing Center window displays the network type in parenthesis after the network name.
2. To the right of the network name and type click Customize.
3. In the Set Network Location dialog box, click Private, and then click Next.
4. In the Successfully set network settings dialog box, click Close
By changing your network location type to private, network discovery is automatically enabled in the Sharing and Discovery section of the Network and Sharing Center window. The following additional file and printer sharing options must be manually enabled:
  • File sharing
  • Public folder sharing
  • Printer sharing
  • Password protected sharing
When all of these sharing and discovery options are enabled, your computer can:
  • Locate other computers and devices on your home network and have other computers locate your computer
  • Share its folders
  • Share its Public folder
  • Share its printers
  • Require user names and passwords for other computers that connect to the shared folders and printers of this computer
To enable file sharing, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to File sharing.
  2. Within the File sharing settings, click Turn on file sharing, and then click Apply.
To enable public folder sharing, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Public folder sharing.
  2. Within the Public folder sharing settings, click one of the following:
    • If you want to share the public folder so that other computers on the network can access the Public share to open files, but not create or change files, click Turn on sharing so anyone with network access can open files. This is the default setting.
    • If you want to share the public folder so that other computers on the network can access the Public share to open files and also create or change files, click Turn on sharing so anyone with network access can open, change, and create files.
  3. Click Apply.
To enable printer sharing and share all of your connected printers, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Printer sharing.
  2. Within the Printer sharing settings, click Turn on printer sharing, and then click Apply.
[Optional] To enable password protected sharing, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Password protected sharing.
  2. Within the Password protected sharing settings, click Turn on password protected sharing, and then click Apply.
Hope you find this helpful info and thanks for using the FixYa service
Kind regards
Feb 14, 2008 | Computers & Internet
Connecting printer to SBS (Small Business Server)
You can physically connect the printers to the server and share it from there or leave the printers connected to your computer and have the server connect to them via a Local Port which routes to your computer!! To do the Create the local ports you'll need to 1.) share the printers on your pc 2.) Go to the server and go to printers in control panel 3.)Click on Add a new printer then next 4.)Select Local Printer connected to this computer; De-select Automatically Detect Printer 5.)Select Create new port and select Local Port 6.)In the enter a port name, enter the full network path to the printer i.e. \\your-pc-name\printer-share-name click ok 7.) Select the drivers for that specific printer(if its not there click on have disk then browse to the drivers to install them) 8.) Continue through the installation until finish) 9.) Repeat steps for additional printers Keep in mind that your computer still needs to be on! You can check to see if your printer support a network card to make them fully network printer you can add them to the server this way and only the server would need to be on! Or you can also get a print server(Device that makes regular printers into network printers). Now when it comes to the scanning, i don't know of any way to share a scanner with just windows alone, but there are third party software that allows you to do that Check out There are also printers that sorta do the scanners sharing by automatically scanning and putting files in a designated area on the network! Hope this was helpful regards, babb
May 02, 2007 | Canon LaserBase MF5650 All-In-One Printer
Toshiba Satellite M115-S1061 Notebook Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
