Question about Behringer Pmp3000 16 Channel Audio Mixer
How do I use the insert I/Os - Behringer Pmp3000 16 Channel Audio Mixer
  • Behringer Master
  • 5,603 Answers
Refer to your manual, page 9, fig. 4.5. You use TRS type cables where the "ring" of the connector is the send to the effects unit and the "tip" is the signal FROM the effects unit.
Not all effects units have a TRS connection and they have only in's and out's. For this type you will have to make special cables that split the TRS at the PMP3000 into a send and receive to plug into your effects unit. These cables are NOT readily available usually and you have to make them yourself. Sometimes you can use a stereo splitter cable but these may have poor shielding for use in this purpose.
Posted on Sep 06, 2010
What driver of umx49 for os Windows 10
sorry to inform you but windows 10 drivers have not been developed by most other manufacturers . and may never be . recover your old OS in/thru the control panel .
Dec 06, 2015 | Behringer U-control Umx490 USB/midi...
Kord pa 50 enciende, pero no funciona
ola claudio
tienes que resetear el organo y despues cargar el os
Dec 13, 2013 | Korg Pa50 Professional Arranger Keyboard...
Voyetra midi orchestrator
The only Voyetra Midi Orchestra Plus software I can know was written for Windows 3.1 and Windows 95. Thus there are several reasons for it to be incompatible with Windows 8. First, it was a 16-bit software; the most common Windows 8 installs use a 64-bit OS. This means that the OS has undergone a number of major changes. The installers are completely different (format/way of talking to the OS). The DLLs that communicate between the software and the OS have also changed. The drivers for MIDI devices will be totally different in the modern OS.
The documentation for Voyetra Midi Orchestra is available here: http://www.turtlebeach.com/support/files/241/ . It is a discontinued product and no one at the company that owns it will be writing a new version of the code for Windows 8. I'm not sure this software will work in Windows 7 32-bit. You might be able to use the software in a compatibility mode from a virtual version of XP. For Windows 7 Pro, Virtual PC and the XP mode package are available as free downloads and can be used if your hardware allows. Windows 8 Pro has Hyper-V but requires a licensed version of any Windows OS that you want to use. For non-pro versions of Windows software, you would need to buy a Pro upgrade. The alternative is to obtain another Virtual machine software (VMWare, for example) and a licensed copy of XP or an older version of Windows. (OEM Windows 7 Pro licenses are still available from many computer hardware vendors.)
I hope this helps.
(Many 32-bit device drivers don't work under Windows 8; older software that didn't run under Windows 7 have similar problems.)
Nov 29, 2013 | Yamaha Music
Hello,i have a problem with my pa800,my display show:usb enable and os not prezent,turn off and put a os to a stick memory and turn on and push intro1,my display is black 75 procent and 25 work,and i cant...
If you are being asked to reload the OS, you will have to do that. SOME devices have trouble with USB sticks that are larger than some limit... that may or may not be specified. If you haven't tried reloading, try it with a USB stick no greater than 1GB... yes they are getting hard to find that small.
Aug 16, 2011 | Korg Pa800 Synthesizer
How do you wipe out everything and put back regular settings on the mpc 2500
from the akai forums:
to set the os back to factory settings press and hold the erase key till the mpc has booted to the main screen.
to erase the harddisk goto either the load or save screen and then choose utility - there you will find the option to format the hdd.
you can also format the drive (or any inserted compact flash-card) from your computer thru the usb connection, but it is recommended to use the internal format because the mpc can be a little picky when you format it from the outside.
at first i would check if there is any folder or the internal memory is set to autoload and just turn that of or point it to another folder of you choice. that way you can keep the factory delivered sounds. maybe you want to use them later, even if it is just to explore the mpc. the factory sounds can be also downloaded later, but be advised that there are different iterations of the stock sounds, depending on whether your mpc shiped with a 32 or 128mb compact flash card.
also the mpc os is not on the harddrive but in the internal memory. to check the version hit mode-> pad10. latest official version is os 1.24. if your main srceen looks different than in the manual check double and triple before you do anything, because the previous owner might have installed the third party jj os which comes in different versions. some of them cost a lot of money! if you find this check the other forum here for the alternative os.
Mar 05, 2011 | Akai Mpc2500 Music Production Center
How do I properly use main inserts? I want ot run a stereo comp and a pair of eqs in line going out of the main insert section. I want to comp and eq overall mix. Thanx
You need to make special cables. The inserts send and receive via the TRS connectors. You will connect to the preamp output of the insert plug which is the "RING" of the jack sending that signal first to your comp and from there to your EQ and then back into the insert plug on the "TIP" of the TRS plug.
Jan 13, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
Zoom H4 recorder ver 1.30 says no card although card is inserted?
Hi. Not sure you still are in need of a solution but since my machine was doing the same thing last night, and I was able to solve it, I thought I'd post anyway.
For my machine, which has a more current OS than yours (mine is 2.20 I believe), I was receiving the same message after transferring material onto the computer. What needed to happen was to reformat the card. If you press "menu", the click on "file" you should have an option to reformat the card. It worked for me and it now works.
Hope that helps!
Sep 16, 2010 | Zoom H4 Handy Recorder
Behringer Pmp3000 16 Channel Audio Mixer Logo
52 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
