Question about Cobra 25 LTD 40-Channels Base CB Radio
Have got a es 880 echo chamber need to find out which wires do what (white screen blue and black) hope some one can help many thanks
Got a es880 echo chamber cybernet wirerd i want to wier to my super star 3900crt whats the wiering code help please thanks Tom
Posted on May 19, 2014
4 Suggested Answers
Mechanic688
  • 204 Answers
SOURCE: wiring for echo chamber to uniden 300
Mick, check out this site, they talk about some of the same equip. as your asking about. It's a very good site.
http://www.radiomods.co.nz/forum/viewtopic.php?p=5303
hope this helps you with your search, Mechanic
Posted on Jan 27, 2008
  • 1274 Answers
SOURCE: Hi all, I am trying to wire a dm-452 echo / power
Pin-1,shield and black, Pin-2,white, Pin-3, red Pin-4,blue.
Posted on Mar 30, 2010
  • 1274 Answers
SOURCE: i need to wire a sadelta es 880 echo chamber to my
First of all, if you will look closely at the end of the mike plug, you will see numbers 1-4. 1- is shield, 2- is audio,white, 3- is transmit-red, 4-is receive,-black,.....hope this was helpful...
Posted on Apr 25, 2010
Testimonial: "spot on info ty. only thing was some one had put new cable on n it had blk wire instead on red. but your help was very gratefully recieved ."
I need wire colors for CB microphone its a TRC
ALTAI PWR MIC - black/braid= earth, red=RX, white=TX, Yellow=MODASTATIC - blue/braid=earth, black=RX, red=TX, white=MOD, Yellow=Spare
SIRTEL ECHO MIC CBE 2002 - black/braid=earth, blue=TX, white=RX, red=MOD007 POWER MIC - brown/braid=earth, green=RX, white=TX, blue=MODSADELTA EC 980 - braid=earth, green=RX, brn=TX, white=MOD
or braid=earth, black=RX, blue=TX, white=MOD
Oct 30, 2016 | Radio Communications
Need wiring diagram to install radio in my 98 stratus es
Check this list for 1998 Dodge Stratus Car Radio Stereo Audio Wiring Diagram:
Car Radio Battery Constant 12v+ Wire: Pink/Yellow
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Orange/Brown
Car Stereo Dimmer Wire: Black/Light Blue
Car Stereo Antenna Trigger: Orange/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Hope this helps, and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment.
Have a nice day and thanks for using FixYa.
Jose.
Oct 17, 2011 | 1998 Dodge Stratus
Need wiring diagram for pioneer deh p2900mp wiring diagram
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps.
Feb 23, 2011 | Car Audio & Video
How do i wire my diehl 880 ?
1) Here is Diehl 880 instruction manual
2) Diehl 880 is 120V timer
-1/2 HP
-1000 Watt tungsten. Tungsten means incandescent light bulbs.
3) Checklist:
a) Your load does not exceed capacity > Timer is too lightweight to control 1500 toaster oven.
b) You need 120V line coming from breaker box with black Hot wire and white Neutral
c) You need 120V line going to Load that also has black and white wire
d) Test each black wire to ground to see which black wire is HOT
4) Deihl 880 sell sheet pdf says 880 is available SPST (single pole single throw) -or- SPDT (single pole double throw).
-The difference is pole #4 on the timer.
-If you are trying to turn one circuit off just as another circuit turns on, then you need the SPDT
-If you are turning one circuit on-and off, then the following instructions are for you
5) Wire clock
-There are 5 poles > look for markings 1-thru-5
-If no marking, then poles 1&2 are probably spaced apart from other poles
-Connect Hot and Neutral wires to poles 1&2 >> this powers clock motor, they go on either pole
-Pole 4 not used
6) Wire timer
-Poles 3&5 are timer circuits
-Connect Hot line to pole 3
-Connect black wire going to Load to pole 5
-Connect white wire from Load to Neutral
Oct 01, 2010 | Diehl TIME CLOCK- 120V 24 HOUR
I need to wire a sadelta es 880 echo chamber to my cobra 25 LTD ST MOBILE . if i have locator grove on plug upwards . ty for any help you can give
Apr 25, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
I need the factory wiring radio color codes to a mazda 626 99 es so i can hook up my new alpine deck
Hi
The wiring color codes for 1999 Mazda 626 are--
Constant 12V+ Blue/Red
Switched 12V+ Blue/White
Ground n/a
Illumination Red/Black
Dimmer n/a
Front Speakers 6" x 8" Doors
Left Front (+) Green/Orange
Left Front (-) Green/Black
Right Front (+) Green
Right Front (-) Yellow/Green
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Blue/Green
Left Rear (-) Blue
Right Rear (+) Blue/Black
Right Rear (-) Blue/Orange
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Jul 31, 2009 | 1999 Mazda 626
I need electrical plan for pluging my radio ,for toyota echo 2005
If you are attempting to install an aftermarket radio Don't butcher the plugs on your Toyota ... simply go to a car stereo shop and buy an adapter plug for $10-$20 then wire it to your new radio ... then just plug them together (the wires on the adapter are marked) You'll likely need a dash kit too ... save yourself from a lot of frustration time and money! ....
May 08, 2009 | 2005 Toyota ECHO
We need a wiring Diaghram for a Realistic TRC 495 Echo Mic.
You can download it at CBtricks.com ....hope this helps....
Dec 08, 2007 | Radio Communications
Wiring for echo chamber to uniden 300
Nov 18, 2007 | Radio Communications
Cobra 25 LTD 40-Channels Base CB Radio Logo
389 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
