Question about Maytag SAV4655A Top Load Washer
We have a Maytag A612 washer. Today it wouldn't fill all the way with cold water (for a cold water load). If I hit the Warm or Hot button, it resumes filling with Hot water, but I don't want Hot so I hit Cold, and it sorta stops...it makes a bit of noise, and looks as if it is filling very slowly. If I push the dial in, it stops. I filled it with cold from a bucket, till it stopped the noise, and when I closed the lid it agitates ok. When it went to rinse, it would not fill, so I filled it with a bucket again and I assume it'll end ok. For the past several months, it would sometimes leak water on to the floor underneath it. I really don't think they're related... Where do I start to diagnose this further & fix it?
  • stanstr Sep 06, 2010
    I did not think it'd be a screen, but I checked anyway. There was only a very slight bit of stuff in there. I cleaned it and it made no difference at all.
    The problem happened suddenly - Cold worked as it should for our first load of wash today and then not anymore.
  • Maytag Master
  • 3,361 Answers
Turn off the cold water faucet.
Remove the water hose from the machine and the faucet.
Clean out the filter screen in the washer water valve.
Look in the hose for a secondary screen and clean it also if one if there.
Not all hoses have screens.
All water valves do have screens.
Posted on Sep 05, 2010
  • steve
    steve Sep 12, 2010
    Your timer is at fault.
When washer fills on warm water mode, it alternates between cold and hot water coming out in spurts. Is this normal, as it doesnt do it on rinse cycle.
yes its normal the reason it does not do it on rinse is that only cold water is used to rinse not /hot warm
please rank this advice if it helped
thank you
Dec 28, 2010 | Maytag MAT13MN Top Load Washer
Can neighbor use washer using cold water hook-up only?
Good day,
Yes if cold wash and rinse are used only. If the selector is set to warm accidentally, water would fly out of the hot water port when filling. Be careful, or hook up another cold water supply to the hot inlet.
Nov 01, 2010 | Maytag LAT3600A Top Load Washer
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer not filling
Hello yamamanot
Welcome to Fixya
My name is Huum,
You said, You did several loads of laundry yesterday but will not fill today or run.
Here are a common thing that cause this problem.
Washer will not fill!
Faulty Water Inlet Valve
The water inlet valve is the device that meters water from the supply lines into your wash tub. On domestic washers, there are two lines, one hot the other cold. These valves are susceptible to mineral build-up and sediment deposits. There are two common failure modes:
Failure Mode One: Valve will not open.
If you can verify that the solenoid on the valve body is receiving the requisite voltage and the valve will not open, then it is faulty. Since the solenoids operate independently, it is likely that one side of the valve will work and the other will not. This can produce strand results such as a very hot wash when warm is selected (due to no cold water). Or the reverse in that the wash water is cold when warm is selected. If mineral or hard water deposits are a problem, you may witness a substantial increase in the time required for the tub to fill. This is caused be a decrease in the flow ware of the valve.
Failure Mode Two: Valve opens but will not close.
This is verified by a valve that allows water to flow into the tub even though no power is being supplied to the solenoid. This one is usually quickly diagnosed when the machine begins to overflow and the power plug for the washer is disconnected from the wall. However, this will not stop the water from flowing into the machine. The water must be shut off at the wall. As with the previous failure mode, the variant of this failure mode is that it may take the valve a while to completely bridge the flow of water after the power has been removed from the solenoid.
How to Diagnose?
There are a couple of ways to diagnose a faulty valve. However, there is a simple test that one can perform that will usually let you know if the water inlet valve is faulty.
Scenario:
When set to cold wash and rinse, the unit will not fill. When set to warm wash and cold rinse the washer will fill with hot water only and will fail to rinse. This is a common scenario where the cold water side of the valve does not appear to be contributing to the fill, but the hot water side does. This symptom could be easily reversed where cold water is being supplied, but never hot water.
So, how can the problem be determined? It is as simple as switching the wire harness plugs on the hot and cold side. In the example above where the cold water is never being supplied, the symptoms would be the opposite when the wiring harnesses were switched. So the machine would produce only produce cold when warm or hot is selected. No water should be present when you select cold. This verifies that the timer, wiring and switches are all in working order. Assuming this tests checks out, you simply need to replace the water inlet valve.
Thank You For trusting us with your guestion
Please remember to leave a rating before you leave!
Dec 15, 2008 | Maytag PAV2300 Top Load Washer
Washer's warm setting alternately fills hot and cold
Call for wty svc- the temp switch is bad; they had many of these built like that Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer won't fill with hot water
If you hear a humming, the coil on the water valve is probably OK. On warm, you are getting cold fill only. (hot + cold = warm) Take the hot water supply hose off the machine and look inside where the hose attached to the washer. There should be a screen inside. Remove it and clean it out. Also, check both ends of the supply hose, as sometimes you will find a screened washer in there too.
Oct 26, 2008 | GE WBSE2090A Top Load Washer
Maytag SAV4655A Top Load Washer Logo
187 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
