Question about Fujitsu FPCRC05 Remote Control
I have a Fujitsu ductless wall unit for air conditioning and heating. I have no manual for the remote control. Where can I get one?
3 Suggested Answers
SOURCE: I have a remote control unit Model : AR-RY7
Jane,if you are still interested: Go to www.fujitsugeneral.com, click consumer, click service and parts, click manuals. Enter the model number of your indoor unit = small numbers on right hand side (e.g.,asu12rmlq and put plenty of paper in your printer. I had 19 sheets. Lots of luck. Bob
Posted on May 24, 2010
SOURCE: Ductless Air Heat remote
The solution is to remove Jumper J5 at the top of the circuit board. For that you will need to open the remote by removing the 3 screws underneath, split open the case and then remove the 4 srews inside. Removing such a small jumper requires precision and you should use a magnifier to focus. You can scratch it off gently using a flat blade screedriver. Test before reassembling. I have succesfully converted both of my remote to Celsius. Fujitsu is guilty for that, the metric system is around for over 40 years everywhere.
Posted on Jun 06, 2010
Tip
Ductless Split Air Conditioner Review
Ductless split air conditioning units are the very best thing for some situations. Of course they can be installed in the place of most any central air conditioning unit. They also are a very good alternative to window air conditioning units. I will explore the use of these units more closely and look at how they can be used effectively.
One of the many problems encountered by the professional is when they are asked to install central air conditioning in an older home that was never designed with air conditioning as even a possibility. The walls may be very thick stone. Often they have very little or no insulation. The floor structures may be rough cut lumber. The joists spacing may be random. Walls and ceilings are plaster and lathe. Basically everything is stacked against any type of ducted central air conditioning. Many log style homes also are not very easy to get any kind of ducted central air conditioning installed. The open ceilings and the bare log wall design does not allow for any kind of ducting. I'm sure there are other situations. These are the ones that I have come across most frequently.
If you have a home or building that falls into one of these categories you may want to investigate installing a ductless air conditioner. This type of air conditioner can be installed in almost any home or building. The small indoor unit can be attached to the wall with a few screws. Most of the units only require that a three inch hole be bored through the outside wall. In new installations the units can be placed on inside walls with some fore thought and planning. For installation in older homes or homes that are already built you will want to plan the units to be on the outside walls.
The outdoor condenser units can be placed up to one hundred feet away from the indoor units. One outdoor unit can be used for many indoor units. Up to four indoor units can be attached to the same outdoor condenser. Some very advanced electronics will control the operation of the condenser and compressor to supply the refrigerant to the indoor air handler units that are running at the time. With variable speed technology the compressor and the condenser fan will only run as fast as needed. This technology has become very efficient in the last few years. You do not have to give up any efficiency with these ductless split units.
Another advantage to these mini split air conditioners is that they can be controlled to run only in the rooms that you actually need air conditioning in. If you are not going to be in a room you can shut down the unit. The units also have timers that can be set to turn the air conditioning on or off at preset times. If you are not going to be home all day the air conditioning can be setback or turned off. The timer will turn on the air conditioning so that you return to a cool house. Central air conditioning is very hard to zone effectively. Also with large central air conditioning systems the outdoor compressor will be running at full capacity even though only a few rooms amy be calling for cooling. There are some central air conditioning systems that are do some staging and variable speed technology. These are not as efficient or as effective as the ductless split technology.
Ductless split heatpumps are another great idea to look at. For a few dollars more you can also very easily have heat from your air conditioning mini split. Then especially in the mild spring and fall weather you can have some very efficient heat with out starting up that big monster of a furnace or boiler in the basement. In southern climates the heatpump version of the ductless split system may provide enough heat year around.
Ductless split air conditioning is definitely something that can solve many problems for some homeowners. Add to that the many advantages of these units and you will find that they are worth every penny that you will invest into them. As with any project like this make sure that you screen your contractor. These units are not for do it yourself people. There are many things that need to be done correctly for these units to work properly and efficiently. A refrigeration license is also required to install these air conditioners.
By doing a little research and hiring the right person you will enjoy many years of trouble free service from your new ductless mini split system.
on Dec 04, 2009 | Heating & Cooling
Removing filter
Go to the following website: http://www.younits.com/asu9rls2-single-zone-wall-ductless-indoor-unit-handler-9000-p-11467.html
Click on the "Literature" button, and then on "User Information Manual" when it is displayed. Your answer is on page EN-13.
Nov 11, 2013 | Fujitsu ASU9RLS2 Single Zone Wall Ductless...
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
We just moved into a rental. It has the Fugitsu wall-mounted Air-conditioner model: ar-jw2 but, there was no manual left behind and we are trying to use the heat, however, it just blows cool air, we're not...
Look, if you select a temperature above ambient temperature, it will switch from cooling to heating.(assuming that the aircon has a heat pump. most do these days.) Just dont rush the aircon because every time you make a setting change, it takes a while to regulate.
Aug 12, 2010 | Heating & Cooling
LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
May 02, 2010 | LG LA185HV Split System Air Conditioner
I have a remote control unit Model : AR-RY7 fujitsu for a ductless airconditioner unit without a manual. I need to know how to program it.
Apr 02, 2010 | Fujitsu FPCRC05 Remote Control
Fujitsu FPCRC05 Remote Control Logo
Top Fujitsu Televison & Video Experts
Tony
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
