Question about Dryers
Drum squeeks when starting and quits later - Dryers
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 12, 2010
Squeek sound when first started cold
check drum,look like around , if look goo change roller
Nov 13, 2017 | Amana Dryers
Ge frontloader dryer is squeeking incessantly, high pitch squeek driving us all crazy. by manually turning the drum i can isolate the squeek, but cannot see anything wrong. does it need to be taken...
There is a teflon bearing that holds the back of the drum you will need to replace. To get to it remove the top cover, take off the control panel, remove the front cover, take off the belt, then take the drum out, ususlly by lifting it up as you pull it foward. While have it all apart I would reccomend replacing the teflon glides at the front that the drum rides on.
Jan 31, 2011 | General Electric DCVH680EJWW Dryer
I have a 5 yr old KitchenAid front load dry that just started to make loud squeaking sound when running or even if I turn the drum when the dry is off. Drys clothing good, just making noise and want to...
You will need to check the tub roller wheels. This is a common noise when the wheel bearings start to ware down. They are not expensive, and you should be able to do this yourself. Good Luck Friend.
Feb 22, 2018 | KitchenAid KEHS02R Electric Dryer
DRYER IS SQUEEKING WHEN IN USE
Main bearing or drum guides are shot - it must be opened up to inspect further.
Grab the drum - and try to move it laterally.
If it moves - your bearing is shot and at almost 2/3 the cost of a new one - repair is questionable.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 27, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
When I turn on the dryer it makes a sqealing noise. Belts seem ok.
there are wheels that hold the drum in place they have berrings that tend to go bad i would replace them it should fix the squeek. also you can put some bar soap aon the beld to quite the squeek if it is not the holding wheels
Jul 21, 2009 | Whirlpool LER5636P Electric Dryer
I have a Maytag Legacy Dryer SDE305DAYW that is squeeking. How do I change the belt?
the belt is not causing the squeek. either the tub rollers, or the idler pully is squeeking. you must remove the front panels and drum to inspect these parts. usually when a roller or idler pully is squeeking, you need to replace them. if they arnt to worn, you can clean the shaft and grease them to stop the squeek, but i dont recomend that, as it will just be a temporary fix and will start squeeking again. this isnt a easy repair if you've never done it. let me know if you have any further questions. Shane
Jun 19, 2009 | Dryers
GE Profile dryer Model# DPSQ475ET4WW
You posted under a DPGT705EC and then a DPSQ475ET4WW, so I am going to guess you have the later one. If it has not been squeaking for an extended time you can get by with just changing the rear drum sleeve bearing (WE3X75). To do this, use a putty knife to push in on the 2 clips about two inches in from the sides at the seam where the front panel meet the dryer top, allowing top to swing up and back. Remove screw holding front panel to side panel near top just under where the top was. Tilt front panel forward and lift off bottom pegs. Swing to side (you don't have to remove wires). Pull drum forward about 6 inches. (you don't even have to remove the belt.) Change sleeve at center back of drum. Make sure to inspect the front drum support slides WE1M481dark ones and WE1M333 white ones (about 1/2 inch x 2.5 inch strips at the top of the front panel which support the front of the drum), as about the time the rear bearing goes, these may be wearing also, especially the one on the left side. You may have to contact GE to obtain an owner's manual (but there is nothing in them about how to service the dryer, just installation and settings, etc.) Parts can be obtained from just about any appliance service company or appliance retailer which does service in your area.
Nov 19, 2008 | GE Profile Harmony DPGT750EC Electric...
Maytag dryer model # LDE5005ADE has a squeaky noise when starting up to dry clothes
thanks for the question. If your dryer squeeks just a short squeek just as you start it thats not a big problem If the noise is there all the way through the cycle it could be the drum rollers locatedat back wall of dryer ,the drum rides on 2 of these they could be worn if its a short sqeek could be a slightly worn belt . thanks for the question The appliance doc
Sep 10, 2008 | Maytag Dryers
Dryers Logo
Top Dryers Experts
