Question about Canon imageRUNNER 1630 Copier
E000 I have a Imagerunner 1630, I keep getting E000 displayed on screen, tried shutting off power and this did not resolve the problem. What can I do aside from paying someone to come out?
E000 is fuser temperature too low could be disconnected or the over heat senser has to be replaced and this code must be reset in service mode to allow copier to function.
Posted on May 13, 2008
How to resolve problem for canon imagerunner 2420L pritner error show "restart if problem persist "
There should be an error code on the screen too, what is it? it should start with E
Sep 06, 2014 | Cannon Office Equipment & Supplies
I have imagerunner 1630 has code e000 how can i fix it
If the machine detects an error in the fixing assembly, the DC controller PCB operates
as follows:
[1] It causes the FSRDRV* signal to go '1' to cut power to the fixing heater.
[2] It causes the RLYDRV signal to go '0' to turn off RL1, and indicates 'E000' through
'E004' on the LCD in the control panel.
When 'E000' through 'E004' is indicated, the NVRAM on the DC controller
PCB remembers an error in the fixing assembly even when the
power switch is turned off and then on. After turning on the power, be
sure to execute the following in service mode to remove the error information:
#7 PRINTER > #4 PRINTER RESET > YES = (*).
sonsunny
Jul 06, 2011 | Canon imageRUNNER 1630 Copier
Error000
This error means that the Fixing heater is not working. It has not reached operating temperature after a specified time. It has probably blown the heater element.
You will need a trained technician to repair this.
E000 errors will not clear until the fault has been rectified and then reset by a technician. This is to prevent any fire risk.
Apr 30, 2010 | Canon Image Runner 1630 Copier Copier
I have a canon imagerunner 1630 had a paper jam and had to pull drum to get it out, now can not get it back in correctly, display reads check toner/drum crg
Before reinstalling the drum make sure the Developer unit is correctly attached to the drum unit. The two clips ( Blue slides on top ) keep the two items together. Canon had two screws that were to added make sure the two stay together when removing the drum. Anyway make sure the drum is squarely installed with you insuring the rear is pushed all the way down. The sensor is located below drum near the entrance to the fuser. Good Luck
Apr 06, 2009 | Canon imageRUNNER 1630 Copier
My canon printer is showing system error E000
What they are talking about is to reset the printer. You should be able to do that by pressing the #7 and then the printer reset button.
Jan 14, 2009 | Canon imageRUNNER 1310 Printer
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
How to get in service mode on Canon ImageRunner 1630
You DO NOT WANT TO RESET THIS ERROR CODE !!!!!!!
there is a problem with the fuser, if you reset it most likely it will melt the rollers in the machine.
check the lamp (burn out), and thermofuse. replace
Oct 15, 2008 | Canon imageRUNNER 1630 Copier
Getting a eooo mesage
E000 error is due power surge or electrical fault within the copier. you can clear the error in service mode.
Sep 30, 2008 | Canon imageRUNNER 1630 Copier
We have a Canon Imagerunner 1630 copier and it is showing Systom Error E000. How can this be fixed?
It is fixing unit error. Try to release error and if when switched back on it happens again, there is something wrong with your fuser.../heater.
Jul 10, 2008 | Office Equipment & Supplies
Canon imageRUNNER 1630 Copier Logo
259 people viewed this question
old marine
old marine
