Question about Ibico 1230 Calculator
How do you thread the paper roll into the calculator?
I have an old Sharp EL-1701C calculator and for some reason can not feed a new roll of paper into the unit? Batteries are new and the feed option works well, just doesn't grab the paper roll to start?
you may need to cut the corners off a little bit on the start of the new roll and feed the paper in while advancing with the calculator advance control/button
Dec 10, 2014 | Sharp EL-1701C Calculator
What kind of paper does the Casio DR-220 hd calculator use?
The Caiso DR220HD takes a Universal 2-1/4" x 150' Calculator Paper Rolls
Calculator and adding machine paper rolls.
2-1/4" wide. 150' in length. 1-ply.
Your local office supply store shoudl carry this. or order online here:
Free Shipping On Casio DR 220 HD Paper Roll DR220HD
http://www.worldclassink.com/Casio-DR-220-HD-Paper-Roll-printer21507-ift198.html
Aug 12, 2014 | Casio Office Equipment & Supplies
How do you load the paper on this adding machine?
    • 1 Cut the beginning of the roll of paper at a 45-degree angle with the scissors for better feeding into the Canon P23-DH V.
    • 2 Lift the paper arm up and slide the roll onto the paper arm. The cut edge of the paper should be feeding down from the outside of the roll.
    • 3 Insert the cut edge of the paper into the small **** at the back of the calculator.
    • 4 Press the feed button in the upper left area of the calculator's keyboard to feed the paper roll up through the calculator.
Jan 30, 2011 | Canon P23-DHV Calculator
How do I install adding machine paper roll
Slide off the upper cover of the calculator, and cut across the paper roll to form a clean end.
If you are mounting the roll externally (outside of the back of the calculator), then look for a slot in the rear of the calculator, which will accept the paper. Feed the end of the paper through the rear slot, and then into the internal feed slot, and hold the [FEED] key. After that, you can flip the arm back to mount the roll and replace the upper cover.
If you want to place the roll inside of the calculator, then you need to feed from the bottom of the roll into the internal feed slot, and hold the [FEED] key. After you are finished, replace the upper cover.
Nov 23, 2009 | Canon P1-DHV Calculator
Replacement paper roll size???
Your calculater takes 2 1/4 inch wide standard rolls of paper. These rolls are available all over the place so you should have no trouble finding the rolls.
Sep 26, 2009 | Sharp EL-1197PIII Calculator
How do you load the paper?
Aug 31, 2009 | Canon P23-DH Calculator
Need help replacing the paper roll on a Casio BIG 12-Digit adding machine.
Aug 21, 2009 | Office Equipment & Supplies
How do I thread the paper tape to the machine
Hello, my name is Curtis, and I am a Sharp Customer Service Rep. What you will want to do is on the back of the calculator there should be a thin horizontal slot that you would feed the paper through, it will only feed so far before it hits a wall on the inside, make sure the calculator is turned on and press the feed key in the upper left side of the calculator, it should take up the paper, if not then give us a call at 1-800-237-4277 or 1-800-BE-SHARP. Hope everything works out.
Jun 08, 2009 | Sharp EL-1801AII Calculator
Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Apr 09, 2009 | Sharp EL-1801C Calculator
Casio FR-2650A
I have lost my manual. I can I thread my Casio Calculator FR2650a?
Aug 06, 2008 | Sharp CS-2850 Calculator
Ibico 1230 Calculator Logo
258 people viewed this question
Top Ibico Office Equipment & Supplies Experts
k24674
Are you an Ibico Office Equipment and Supply Expert? Answer questions, earn points and help others
