Question about Kenmore Dryers
I have a Kenmore dryer, 2 yrs. old. Out of the blue, when you push the ON button nothing happens. Trouble Shooting from my manual- everything it could be is ok. One strange thing- the light is staying on even when the door is closed............ It is Model # 110-86752501 Kenmore Series 70. Any clues?
  • Kenmore Master
  • 3,361 Answers
The drum light staying on gives us a clue to the problem.
The door switch controls the drum light as well as power to the timer for the machine to start.
Since the light is on with the door closed,that meabs the door switch is defective.
It must be replaced .
The dryer will most likely start and run after door switch replacement.
If not,remove the rear panel and locate the thermal fuse on the left side of the exhaust vent and replace it.
It is about 1 and 1/2 inches long by 1/2 inches wide and white in color.
Do the door switch first.
Posted on Sep 05, 2010
Kenmore 80 series electric dryer Model - 110-60882990 The dryer won't turn on. Once the start button is pushed it makes a single clicking noise. If I open/shut the door and push the start button...
check the actual door switch,, you can jumper it to see if this is the problem, Just connect the 2 wires together , if this cures the problem replace the switch
May 25, 2011 | Dryers
I have an older Kenmore 70 series dryer. When I push the start button nothing happens. I know its not the electrical outlet.
Your thermal fuse is bad located behind access panel between fan and exhaust. Little white plastic fuse with 2 blue wires connected to it. Rate me if I helped you. Thanks and good luck!
Aug 26, 2010 | Kenmore Dryers
I was given for free a kenmore he4 smartheat quietpak 9 dryer from a friend that was moving overseas. I have owned it for 1 week and all of a sudden it will not turn on. All the lights come on (red) and...
Have you tried unplugging the power cord yet? Leave it off for 2 minutes. It may reset the unit and solve your problem. If not, let us know and an expert from this category will try to help you further.
May 17, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 80 series dryer, won't turn on
Thanks for the question When you push the start button was thera hum if there is a hum when you push start you need a new motor THanks for the question The appliance doc
Jul 18, 2008 | Kenmore 63942 Dryer
Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Oct 31, 2007 | Kenmore 84152 Electric Dryer
Kenmore Dryer
The start button works like a push-on switch that engages the timer switch. It's all one unit. It isn't engaging because the internal lever the engages the switch is either broken or worn out. The start timer/switch will need to be replaced.
Jul 09, 2007 | Fisher and Paykel DG05 Gas Dryer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
140 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
