Question about Deadbolt Locks & Locksmithing
Rona electronic dead bolt put new code in and it will lock but all that is needed is to push unlock button to unlock no code is needed
This lock now has an automatic 'handling' determination.
the instruction manual is slightly incorrect.
you should insert 3 of he 4 batteries and press and hold c and the lock buttons. while holding, insert the final battery. the lock will do a few lock attempts and then finally the bolt will slide the correct way and then a melody will play to confirm function
http://www.forgelocks.com/userfiles/files/pdf/en/Binder1.pdf
Posted on Jul 13, 2012
SOURCE: Lock works in reverse
You need to set the door direction jumper pins inside the unit. From LH to RH or vice versa depending upon your door.
Posted on Jun 01, 2009
  • 68 Answers
SOURCE: center button unlocks insted of locks code locks insted of unlock
Take off the inside cover and move the door direction jumper over one pin.
Posted on Mar 23, 2009
jyackle5
  • 8197 Answers
SOURCE: I have a larson storm
Sorry the lock has gone out on you and needs to be replaced. We can not help you with this lock.
Good Luck
Posted on Dec 01, 2010
SOURCE: Bought a electronic deadbolt at Rona (Rona
Rona Electronic Deadbolt Lock Instructions:
Default Master Code:123
Resetting Master PIN:
  • Remove batteries and put them back. You will hear a long beep and a short beep.
  • Press and hold the 0 button until you hear 3 long beeps and the LED flashes red for 3 seconds. You are now in program mode.
  • Within 10 seconds, key in a new master PIN (up to 12 digits) and press the UNLOCK button.
  • Key in the master PIN again and press the UNLOCK button. The LED will flash green for 1 second and the resetting is complete.
Adding a PIN:
  • Key in master PIN and press UNLOCK button
  • Press and hold 0 button until you hear 2 short beeps and the LED flashes for 3 seconds.
  • Release 0 button and you are in the Add PIN mode
  • Within 10 seconds, enter a new PIN and press the UNLOCK button. You will hear one beep.
  • Key in the new PIN again and press the UNLOCK button twice. When the LED stops flashing the PIN has been added.
Posted on Apr 13, 2011
  • 15 Answers
SOURCE: Have a Rona electronic lock (Weiser) and the key
First, I fix this problem after an hour of try.
I conclude that this dorr lock is better that is appear. Is not a 2 codes door lock, it's a 3 codes one.. and the problem you have is the third code not reset. You can put the same code in each third emplacement. you have just to press the program button 3 time for the third code...
I determinate that I put the third code by error the was i program it the firs time.
I guide you...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Posted on May 15, 2011
How to change baterry o schlage be365
To change the battery on the BE365, you need to remove the inside cover by removing the two screws (one above and one below the deadbolt knob). Be careful to tuck the wires inside the lock so that they will not be crimped when you put the cover back on.
Do you here a beep and see a flashing light? Usually if pressing the Schlage button unlocks the deadbolt, your installation was done improperly. The cam on the base plate must be vertical and the bolt must be correctly installed.
You will always be able to lock and unlock the deadbolt with the inside thumb knob.
I hope this helps.
Dec 04, 2013 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Shlage keypad dead bolt unlocks when you press the
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Aug 31, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
I bought Rona Collections Electronic Deadbolt. My problem is when my door is locked and when you pressed padlock button without entering your pin code the door will unlock. Any solution to this problem?...
You must ensure the deadbolt is in the locked position when attaching the control mechanism. The control mechanism must also be set to the locked position. Turn the manual knob to the left then attach the mechanism (with the batteries) to the flat pin. You can do all of this with the door open, so you can enter the codes. My initial install created the same issue. It worked properly out of the package, so that meant that I screwed something up. You don't need to return the item. Just do a little fault finding.
Sep 19, 2011 | Deadbolt Electronic Keyless System -...
How do I lock the door with the key pad? I can unlock it fine but I can't get the door to lock. Don't have the manual. what buttons to I press?
Push the Lock button on outside touch pad to extend latch bolt 1" which locks the door when you leave.
Enter your desired personal code to retract the latch bolt completely which unlocks the door when you return home.
The T-turn on the inside of the door is used to extend (lock) or retract (unlock) the latch bolt when you are inside.
Using the key from the outside will also extend (lock) or retract (unlock) the latch bolt.
This Touchpad Electronic Deadbolt should be accompanied by a Kwikset Knobset, Leverset, or Handleset.
I cut & pasted the above from the installation instruction sheet.
Here is the link to the entire installation instructions sheet (manual):
http://s7d5.scene7.com/is/content/BDHHI/40486-02
It is a .PDF file, so if you aren't able to view it, download and install Adobe Reader from this site first:
http://get.adobe.com/reader/
If you are not able to lock the door using the outside touch pad's lock button, you may need to reprogram the door's "handedness", which gives the lockset the ability to be used on doors that have their hinges on either the right or left side of the door (right-hand or left-hand door).
The instructions for that are found on Step 4.9. This is also an excellent time to change the batteries, which is recommended yearly.
Aug 01, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Dead bolt does not align with the keypad, every time i turn the dead bolt it only goes in so far then i hear a click, and if i push the lock button it doesnt turn i hear a continuous click then the keys...
I have included a link to the installation instructions for the Kwikset 909 lock. I think that if you go through the installation instruction routine carefully, you will solve your problem. Pay particular attention to Step 8, the synchronization routine.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Apr 16, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
To unlock the bolt no code is needed... just by pushing the lock button it unlocks what do i have to do to make it function proporly
You need to reset the lock, so it will be set to the correct handing (left or right hand door).
Open the door and extend the lock bolt. Remove the battery. Press the reset button three times and wait 20 seconds. Push and hold the lock button, while inserting the batteries. Hold the lock button until the bolt starts to move. Allow the lock to complete it's learning cycle.
Program a new code and test.
Jan 09, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Bought a electronic deadbolt at Rona (Rona Collection). Installed it and i can open/close it with the remote control or a key. Can't open it by entering a code. I thought the factory code was 1234, but...
Adding a PIN:
Sep 23, 2010 | Deadbolt Locks & Locksmithing
Brought new keyless dead bolt. Put it in a door that opens in with hinges on right side. The problem is that the motor wants to turn the dead bolt the opposite direction, unlock extends deadbolt,...
My lock adjusted itself automatically... You have to hold the lock button in (on the exterior side) while you insert the battery pack - the deadbolt will cycle in and out, then beep a couple times. You'll be holding button for maybe 10 seconds.
I have to say while this step is included in the instructions in a big red box, it says nothing about why or what its doing, so I imagine many people miss this...
Aug 25, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
Have a Rona electronic lock (Weiser) and the key works... will lock electronicly... but do not know the code... I have removed it from the door and replaced, but is there a way to reset the code?
I guide you...
Jan 23, 2010 | Weiser Lock Powerbolt 1000 Lock
Feb 19, 2009 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Locks & Locksmithing Logo
718 people viewed this question
Top Deadbolt Locks & Locksmithing Experts
jdthefixer
David Belitz
David Belitz
Are you a Deadbolt Lock and Locksmithing Expert? Answer questions, earn points and help others
