Question about Electronics - Others
My powertech MI-5085 500w stopped working and the overload light is on , I have unplugged the laptop and printer it is connected to , but still the light comes on as soon as you turn on the inverter. Had the battery checked and was told it was all but dead , so I have replaced it , I was just wondering if there is anything else I should check as the unit is still showing the overload alarm. Thanks for any help , Dan Frost.
2 Suggested Answers
  • 4961 Answers
SOURCE: Powertech 500W Inverter ac light off overload light on.
You might want to post this in a different section. This is the computer laptop section.
Posted on Aug 19, 2012
Red light on and beep sound contionus came
Hi Subramanian,
If this is a small desktop UPS like the one pictured in your post then it is most likely overloaded. If you have a printer plugged into the UPS then try unplugging it from the battery backup outlet(s) and into the surge protection outlet(s). Other things to try would be to unplug connected devices until beeping stops... and a good away to narrow it down is by unplugging one device at a time to find the one causing the fault. If one device is the cause then plug that device into a surge outlet, another UPS, or into the building outlet -- if not then plug it back in and try another device until you find the one that is overloading the UPS. **There may be more than one device that is plugged into your UPS that is overloading it**
Hope this helps. If you would like more assistance please give me a call: 407.380.9200.
Nov 01, 2013 | Computers & Internet
My pc wont continue booting because of usb overload
what makes you think its usb overload ?
Check your computer's power cable and the power cables to any devices connected to the computer. Make sure all cables are firmly plugged into electrical outlets and into the computer and other devices. If you have an extra power cable for your computer, swap it in to see if your computer's power cable is the problem. Remove your computer's battery, if it is a laptop, and connect the computer to a electrical outlet to see if it will start up. Sometimes a discharged battery will prevent a laptop from powering up. If your laptop still won't power up, remove the power cable, replace the battery and try to run the computer off battery power. Unplug your computer and plug a lamp or radio into the same electrical outlet and see if that device works.
If the lamp or radio doesn't work, the outlet is the problem. Unplug your computer and open your computer's case, if it is a desktop system. Look for loose cables, cards and connections and attach them firmly. Blow out any dust with a can of compressed air. Also, check your computer's memory chips to make sure they are all plugged in and seated properly. Close the case once you are done and plug in the computer. Disconnect any USB devices connected to your computer and try to power up the system. Sometimes a USB device not connected properly will stop a computer system from powering on. Disconnect any new devices recently added to your system. Sometimes new devices will conflict with other hardware within your computer and cause an overload on your computer's power supply. Disconnect any other devices connected to your computer such as the keyboard, mouse, monitor, printer or scanner and plug your computer into a electrical outlet by itself. Check to see if the computer works. If does work, shut it down and connect just one device, such as the monitor. Turn on the computer and monitor and see if everything works. Continue connecting devices until you find the one that is stopping your entire system from powering up. Hope it helps.
b>
Jan 23, 2013 | Computers & Internet
Aug 18, 2012 | Computers & Internet
Mi digital mouse stop working
try to unplugging it and plug it back in this sometimes works
Feb 15, 2012 | HP Compaq 6720s Notebook
I HAVE A MINUTEMAN ENDEAVOR SEARIES AND IT OVERLOADS FOR SPLIT MOMENTS THROUGHOUT THE DAY. EVERYTIME THIS HAPPENS I GET AN AUDIO LOAD WARNING COMING OUT OF MY COMPUTER SPEAKERS. IS THERE ANY WAY TO STOP...
well try to press the test bottom for one sec and see it work.. and one thing why there a overload maybe u hav plug more the the power consumtion of the ups.. try to seperate the load to other ups or plug to other source. one thing is don every connect your printer to the load it may cause your ups to be overload if depend on your ups watts you are using??? if all this matter is not working it mean your ups is having the hardware issue.. tell how many VA or capitcal of ups u are using? how many load u is there indicator? what type of equiments u are connecting to the ups?? give mi the exact mode like (eg.ED1000RM2U and ED1000RMT2U
  • ED1500RM2U and ED1500RMT2U).. if you can tell mi all this i will be easy to find out what the cause of the problem..
  • Mar 22, 2009 | Minuteman S 1000 - Smartsine Series...
    Cant'install lexmark x5470 printer driver
    Clean the registry. Expunge all temp files. & reinstall........sodeep (Use cCleaner)
    Mar 19, 2009 | Acer Aspire 5610-4648 Notebook
    My refridge and freezer would stop working
    there is a saftey overload switch on the compressor when the compressor is over heating it cuts out. when the fridge is turned off it resets the switch. So now the compressor has burned out totally. you more and likely need a new compressor
    Feb 03, 2009 | Frigidaire FRT21P5A Top Freezer...
    My printer is not printing Lexmark 5400 series
    www.lexmark.com has the drivers you'll need by model and operating system
    http://tinyurl.com/6qcpgy
    Jul 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
    ACER ORBI CAM
    Does the camera still work without the green light?
    Nov 26, 2007 | Acer Aspire 5100 Notebook
    Electronics - Others Logo
    125 people viewed this question
    Top Electronics - Others Experts
    Are you an Electronics - Other Expert? Answer questions, earn points and help others
