Question about Krups FME2 Coffee Maker
Error message states NO Water, but there is. Krups FME2 is about 9 months old
5 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: Krups FME2 Error Message
if you still have the receipt, you can get it repair or replace under the warranty, unless the warranty is for 90 days. in that case you are toast.
time for a new one.
replacing the parts is half the price of a new one.
Posted on Oct 20, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Krups FME2 will not flow water.
Does it sound like it is boiling water at all?
If it is boiling, but not giving hot water, then the one-way valve is stuck.
If it is not getting hot (on the soleplate base) then usually the element has blown.
These machines use the steam generated by boiling as a means to move the water up - like a geyser, and need the heat to move the water.
Replacement elements are available, and the valves usually just require cleaning.
Posted on Jun 29, 2008
  • 79 Answers
SOURCE: FME2 Coffee Maker
From page 9 of the manual:
Setting and Adjusting the Clock
• The machine must be “off“.
• Press and hold the prog button (o) for 3 seconds: the hours will blink “88 _ _“.
• Adjust the hours in steps by pressing the h/min button (n).
• Press the prog button : the minutes will blink“ XX 88“.
• Adjust the minutes in steps by pressing the h/min button.
• Confirm the setting by pressing the prog button.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={FA4AA2D9-9799-4F8F-8136-8FEB029407FD}&SelectedProdRef=FME2
Posted on Aug 28, 2008
SOURCE: how can I set the automatic timer on the Krups FME2 Coffemaker
Problem solved...
Found the manual for my coffemaker online
Posted on Dec 15, 2008
Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Oct 26, 2009 | Krups Small Appliances Espresso Machine
On FME4 coffee maker the error message CALC
it means de"CALC"ify its detecting calcium build up the manual says to run white vinegar without the filter followed by two clean water cycles goto krups.com to download the manual
Oct 10, 2009 | Krups FME4 Coffee Maker
Error message states no water, but there is...
Unplug the device and plug back in after 1 min. If it still fails, then you have a dirty water level sensor or the control circuit board is fried. Empty the water out and fill it with vinegar as full as you can without overflowing. Let it soak overnight and turn the machine on (without coffee in it). Turn off after 30 secs.Turn on again and allow it to finish the cycle.  Discard the vinegar. Run three more brewing cycles with water only and it will be OK to use. If this does not cure it, then the only cost effective way is to replace it.
Apr 26, 2009 | Krups FME2 Coffee Maker
No froth
ing it back to store and tell them ur problem....u can ask for repair or a new machine
Apr 19, 2009 | Krups XP4030 Espresso Machine
Krups nespresso not heating water
That is a faulty thermostat or a defective control board.
Contact Krups and have the machine replaced.
Contact - Krups International
Feb 17, 2009 | Coffee Makers & Espresso Machines
Krups FNC3 Espresso Machine
If it's only 18 months old surely it will still be under some sort of manufacturers guarantee, you don't bin 18 month old coffeemakers nor should you be paying to fix them. Put the problem back in their lap.
Aug 01, 2017 | Krups Novo 3000 /FNC3 Espresso Machine
time for a new one.
Oct 20, 2008 | Krups FME2 Coffee Maker
Krups FND1 water escape
What position do you have the knob in? According to your manul it should be in position 9 not in position 8 for steaming.Good Luck.
Apr 11, 2008 | Coffee Makers & Espresso Machines
Error message: water tap closed .
check water inlet valve clean of rubbish from water inlet hose
otherwise water inlet valve maybe faulty
Dec 08, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Krups FME2 Coffee Maker Logo
91 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
