The printers RAM has failed this is where the info is stored during the print run, the site below may be able to supply the parts needed.
http://www.laserprinterservices.com/hp4600/hp4600.html
Usually, when you try to print a document or a web page, like if you right-click a page and click print, you should get a print window where you will find the section to indicate the number of copies to print. on the same area, you can usually find the Collate option. Just select it and click OK. In other cases, you may find this option on the Printer Properties.
in case the previous suggestion did not work, next option would be to try reinstalling the printer driver .
sorry, was not able to get back to you sooner on this one. While on the document or page, hold down CTRL key and press the letter P key to open the Print window. Select your correct printer name. You should also find the section with the number of copies to print. By default, the COLLATE option is grayed out since the number of copies is set to 1. If you set it to at least 2, the COLLATE option will be activated so you can select it. If in case you continue to experience issues printing, proceed to uninstall and reinstall the printer driver.
Solution says, "Install an EIO hard disk"
It says, "Printer not configured to collate". I am interested in how to collate. Can you help me? Thanks, tom
I am not able to find the "collate" option. Can you please tell me where I can find it? Looked at print, print properties, etc...thanks, tom
