Question about Toshiba TEC B-SX4 Thermal Label Printer
NEED TO CALIBRATE MY SX4
Cant print multiple labels without it being off slightly every label after the first
  • texas714 Aug 20, 2008
    I have paper jams showing up after every tag, and extends half way to the 2nd tag...
    Champion:
  • 254 Answers
Switch the printer on with the buttons feed and pause pressed.Press feed to display Sensor adjust. Press pause until transmissive is displayed. With the liner in the cells press on restart until a star is displayed next to the value (around 4.7V) press Pause the calibration is finished. In my opinion, you should check the size of your label and the distance between the labels (label gap) and also check that you have selected the correct detection (Transmissive for gap or relective for black mark)
Posted on Sep 02, 2009
Paper gap sensor
Ok, this is easily solved in 3 different ways
1) Driver: Download the greatest driver I know, the one developed by the NiceLabel guys: www.nicedrivers.com
you need to go on right click in te driver(Start/Control panel/TEC Toshiba...) choose properties. In options you will have the chance to verify the gap mode(continous/black mark/ etc). You can also calbrate your printer from there.
2) If your printer needed to calibrate, turn-it off, then, by holding the feed button, turn-it on and let go after 3 seconds, or after you see a light. It will calibrate automatically with your label size at that moment, it may also print the printer settings, so be prepared for stoping the baby.
3) If you have a barcode software(did i say I reccomend NiceLabel?), you can set the instructions on 1) directly from printer settings.
Good luck, peace.
Aug 14, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
How to print label on b-sx4 label printer
You must use the option send file to printer in the seagull driver not print else it is converted to graphics and sent to the printer.
May 16, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
Hi, I have a TEC SX4 printer which im trying to
There is usually a setting in your label software or printer driver that lets you choose between thermal transfer printing or direct thermal printing. Make sure your setting is on direct thermal.
Hope that helps !
Aug 12, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
I have a TEC SX4 printer and im trying to convert the machine to print on thermal labels without a ribbon.. I don't know how to do it! Can anyone help me please
Quite simple.
- Remove the ribbon
- in the support tab of the driver select direct thermal.
- Send a test print to the printer.
It's done
Aug 11, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Paper jam error message
This problem is a detection problem, due to a bad sensor selection or incorrect label size.
If the labels are white labels with a separation between each, select TRANSMISSIVE. If the labels are preprinted, select the TRANSMISSIVE PREPRINTED LABELS and set the threshold doing this.
With the printer in ONLINE, press PAUSE once, the message PAUSE appears in the display, press and hold on the PAUSE key, TRANSMISSIVE is displayed, release the key and press PAUSE until labels starts to feed, let feed some labels (5 or 6) and release the key. Press Restart and start to print.
Dec 08, 2009 | Toshiba TEC B-SX4 Thermal Label Printer
Zebra S4M label printer
i think it's a GAP problem, try to calibrate from the computer, if that's not solve the problem, find the CALIBRATE option on the LCD panel a. just follow the instruction to do manual calibrate
Aug 13, 2009 | Zebra S4M Thermal Label Printer
The label prniting is not work properly, print two
you can calibrate from printer driver .Go to printing preference select advanced setup and select Calibrate
Or you can calibrate from printer.go to menu in the printer and select media and ribbon calibration it will calibrate ribbon and label
Aug 06, 2009 | Zebra S4M Thermal Label Printer
TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Dec 08, 2008 | Zebra LP 2844 Thermal Printer
White space between labels
OK, guys, I spent some time with this, and you have to do this:
If you use ZebraDesinger, go to File-Printer settings-Advanced Setup-Calibrate
The printer will need approx. 40cm of the paper (labels) to calibrate where is the begining.
After that it was working good.
Just make sure, you have input correct With and Heigh of the label.
How to do that?
-get into Label setup wizard
-choose the printer -> click on NEXT
-choose stock type and stock name (I have ALL and <NONE>) -> click on NEXT
-set Height (count with space between labels, so measure from the start of the label, till start of another and Width. -> click on NEXT
-set other settings -> click on NEXT
-set width and heigh (this time without space between labels)-> click on NEXT
-Finish
then calibrate the printer and enjoy your work.
Apr 22, 2008 | Zebra 110XiIIIplus Direct Thermal/Thermal...
Toshiba TEC B-SX4 Thermal Label Printer Logo
1,743 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
