Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
HOW MUCH OIL DOES A SEARS CRAFTSMAN 5HP AIR COMPRESSOR HOLD
  • 1388 Answers
SOURCE: type of oil
Air compressor pumps can use different grades of oil depending on weather conditions and usage, however do not use engine oil. Some Ingersol Rand pumps use a synthetic oil available through WWGrainger on the web. (generally not model specific) If this pump is lightly used you can use the less expensive compressor oil sold at Lowes lumber made by Campbel Hausfeld. It sells for less than $3.00 a bottle. Generally speaking, under normal weather conditions and light duty use, do not worry about the weight of the oil; just make sure that it stays clean and at the right level. If your compressor is running hot, it may be due to other problems like the check valve, head gaskets leaking between cylinders or chambers or high usage. If, however you just want the best oil for your compressor, use the synthetic. It is usually colored blue or green. This oil is special formulation to prevent breakdown in high heat and will not allow carbon for form on parts or inside of the hoses. enjoy
Posted on Nov 29, 2008
virgils
  • 39 Answers
SOURCE: craftsman air compressor, oil build up in the air line
worn compressor rings, not a real issue, I assume it is more of a build up over time, say a gram of oil is blown into the lines every year, well one gram would not be noticed nor two but since it soes not evaporate it builds up to the point that you can see it, some oil is blown by brand new compressors and over time gets to be more and more, but as long as you are still getting full pressure you do not have to service the compressor, but since this is being used on water pipes I would install a trap inline to catch the oil
Posted on Oct 13, 2008
SOURCE: Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
Posted on Nov 26, 2008
  • 1388 Answers
SOURCE: Oil capacity for craftsman air compressor circa 1978 model #106..
I have a 2hp craftsman air compessor with a two cylinder pump, Here is the info from my manual as far as oil capacitity:
Remove oil fill plug and slowly add
a compressor oil until it is even with the
top of the oil fill hole. NOTE: Do not
allow oil to be lower than 3/8"
from the top at any time. When filling
the crankcase, the oil flows very slowly
into the pump. If the oil is added too
quickly, it will overflow and appear to
be full. NOTE: Crankcase oil capacity is
approximately 16 fluid ounces.
I buy my compessor oil from Lowes in the tool department. It comes in 16oz and sells for about $3. I wouldnt worry about how many ounces it holds but rather that the oil level is to top of filler hole. Lowes also sells a synthetic oil for about $7 and is recommended for severe conditions (hot / cold / used all day). Good Luck!
Posted on Apr 26, 2009
  • 64 Answers
SOURCE: i have a sears craftsman air compressor 5hp 22 gal
The regulator and emergency release valve need to be checked. It should shut off once the PSI hits the target pressure. If the motor is staying on and the pressure never raises above 70 lbs, then air is escaping, either the emergency prv or a seal has blown
Posted on Sep 24, 2009
Testimonial: "i dont think the valve is leaking so it must be the ring how do i chg. that"
Manual for craftsman 33 gal 6 hp 919-165500
Craftsman Portable Oil Free Direct Drive Air Compressor Parts 919 165500
Illustrations of Sears Craftsman at the link above for:
Portable Oil-Free Direct-Drive Air Compressor
Jan 30, 2018 | Craftsman Air Tools & Compressors
Craftsman 5hp electric model 19551, type oil used and amount?
if you go to you tube Craftsman 3 gallon air pump oil change ,it tells you the brand of oil and shows the amount needed . hope this helps .
Dec 22, 2015 | Craftsman Air Tools & Compressors
1988 20 gallon 5hp sears air compressor leaking quite a bit of oil. Can it and is it worth repairing?
I would think that is is actually coming from the crankshaft seal and running down. Does it leak when you are not using it, or just when it is being used? If it leaks even when it is not being used then it could be the drain plug. If it only leaks when being used then I would look at the crankshaft seal. And yes it would be very feasable to repair it, because like all things they don't make them like they used to.
Apr 23, 2012 | Craftsman 33 gal Air Compressor 6 hp...
What type of oil to add
Mobile synthetic 10-30 , Craftsman compressor oil if K-mart or Sears are near by. You can also use a non-detergent 10 - 30 motor oil , I use Mobile or Craftsman in mine. I have three - one is a Campbell Hausfeld this oil is per their book - (minus the Craftsman)
Don F
Sep 08, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
What type of oil does me Craftsmen 1.5 air compressor use
It uses a special oil, not motor oil, it is called Craftsman 2 Stage Compressor Oil, here is a link to the oil.
http://www.sears.com/shc/s/p_10153_12605_00916427000P?i_cntr=1295304743644
Jan 17, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a sears craftsman air compressor 5hp 22 gal tank single cyl oil free it gets up to 70 psi does not shut off but will go no higher i cant find any leaks just bought it used guy used it to paint i...
Sep 24, 2009 | Air Tools & Compressors
Craftsman 1/3 hp compressor leaking oil
most defintly you need a head gasket but you will also need piston rings look up your local sears service center not automotive or the store you want appliance service center
Jun 17, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My 5hp 22gal craftsman compressor wont go above 30lbs pressure
your presure guage sensor has gone a miss you can try adjusting it but I would replace it. if you get it wrong you can over pressure you tank and it can explode
Jun 10, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Apr 25, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
367 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
