Question about Dometic Rooftop RV Air Conditioner
It starts an stops an will trip the cir - Dometic Rooftop RV Air Conditioner
  • Dometic Master
  • 43,501 Answers
The compressor is going bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 07, 2010
How to Configure Rate Limit on S2700&S3700&S5700?
Configure Rate Limit on S2700&S3700&S5700? When you configure rate limit, the following configuration is recommended:
· Set the CIR, CBS, and PBS values but not the PIR value.
· CBS = 200 x CIR
· PBS = 2 x CBS = 2 x 200 x CIR = 400 x CIR
The CIR value is expressed in kbit/s, and the CBS and PBS values are expressed in bytes.
Set the rate limit for outgoing packets on the interface to 10 Mbit/s.
[HUAWEI] interface gigabitethernet 0/0/1
[HUAWEI-GigabitEthernet0/0/1] qos lr outbound cir 10240 cbs 2048000
Set the rate limit for incoming packets on the interface to 10 Mbit/s.
[HUAWEI-GigabitEthernet0/0/1] qos lr inbound cir 10240 cbs 2048000
NOTE:
A traffic policy can be used in the physical interface view, Eth-Trunk interface view, and VLAN view.
Nov 22, 2016 | Cameras
How to Configure Rate Limit on S6700?
When you configure rate limit, the following configuration is recommended: Set the CIR, CBS, and PBS values but not the PIR value. CBS = 200 x CIR PBS = 2 x CBS = 2 x 200 x CIR = 400 x CIR The CIR value is expressed in kbit/s, and the CBS and PBS values are expressed in bytes. Set the rate limit for outgoing packets on the interface to 10 Mbit/s. [HUAWEI] interface ethernet 0/0/1 [HUAWEI-Ethernet0/0/1] qos lr outbound cir 10240 cbs 2048000Set the rate limit for incoming packets on the interface to 10 Mbit/s. [HUAWEI] interface ethernet 0/0/1 [HUAWEI-Ethernet0/0/1] qos lr inbound cir 10240 cbs 2048000 S6700 Switch Thunder link com
Nov 21, 2016 | Computers & Internet
PAP FD DRVR CIR
My P7005 displays PAP FD DRVR CIR error
Sep 06, 2012 | Printronix Matrix Office Equipment &...
All breakers do not trip when overloaded
YES, this is true! Overloaded to what degree? Sometimes, a 20 amp circuit breaker can handle an amp, two, or a few more before tripping. This happens for a number of reasons, but for the most part - they're designed to handle a little bit more than their stated (eg. 20 or 30 amp) amperage. The electrical code states that overload protection (cir. brkr's) should not exceed 80% of their load. So on a 20 amp breaker, you shouldn't exceed 16 amps - and on a 30 amp breaker, it shouldn't exceed 24 amps. I hope this is what you were looking for. If not, feel free to contact me again and I will provide you with more information. Good Luck!
Mar 29, 2010 | Sylvania Circuit Breaker
I have grandfos circulator pump the wiring was hooked to incoming line not cir. line is this ok
That is still okey, however, it would have been advisable to hooked it to its own cir. line. I assumed that the cir. line is dedicated to the grundfos pump complete with its own circuit breaker or fuse cutout.
Since you are just asking if it is okey, well it is. But
the line must be going to a circuit breaker (20 Amp trip), for 220 volt line; and 40 Amp trip for 110 volt line
before it goes to the grundfos pump. Just use the circuit breaker or fuse from the cir. line. And take the original cir. line off from where this is connected, and keep it for future use.
Nov 28, 2009 | Plumbing
Removal of rear outter door handle
Ok
Remove plastic plug on the inside of door there is 10 mm hole use a hooked pick set pick put through the hole and pull the plastic cir clip towards the back of the door that will release the smaller part of the outer handle then the handle itself can be taken out.this is so simple but so deceiving the actual cir clip is hard to notice because of all the plastic **** on the inside backing plate the cir clip is just on the inside of hole look hard it is 2mm thick & 20mm high (black plastic) place point of pick in between backing plate & cir clip hook it and pull back the front door is based on the same principle but is a lot easier
Jun 10, 2009 | 2008 Audi Q7
1995 gmc truck shift problems
It sounds like the power supply is dead for the transmission. Check the transmission fuse for power.
May 30, 2009 | 1995 GMC Sierra C1500
How do i remove the outer rear door handle on a 07 audi Q7
Ok
Mar 24, 2009 | 2008 Audi Q7
Dometic Rooftop RV Air Conditioner Logo
310 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
