Question about Whirlpool Duet GHW9150P Front Load Washer
I'v had a whirlpool duet washer for about 3 years and all the time we have had it it shakes so bad it moves around in it spot what can i do to fix the problem
  • 15,935 Answers
It appears your vibration dampers or drum roller bearings have failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Whirlpool duet front lading washer, GHW9150PW4
Could be drum bearings gone Quite a big job hence costly with around 3 hours labour plus parts, some models need half drum as the bearings are loaded in here,leak could be door boot seal at 7 yrs old not sure if worthwhile as its about the end of its working life.Good luck
Apr 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Why does my new whirlpool washer wtw4950xw2 cause clothes to smell musty? I also noted when shaking the tub after load is complete, water sound is audible, although tub is empty. Could there be a check...
This machine is a lemon It will break down in a year or less. I have the same machine. The gear box, motor, and now the control board went bad. I haven't been able to use it for 2 months now while they try to fix again & again
Oct 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool washing machine Model number ghw9400pwo is shaking vilently and has started to wear on the plastic around the front of the drum causing plastic pieces to fall off of it. It was bought in 2005...
with nothing it it put one of the flippers at the 12 o'clock area and push up and down. if it clunks and it prob. will the rear bearing is going bad, the more it moves the more bad it is. if it is the case its time for a new washer. the repair of the unit will be more then its worth.
Jan 10, 2011 | Whirlpool GHW9400 Duet Washer
Vibrates, shakes and moves around and has a lot of noise while spinning. It has been leveled and the floor seems sturdy enough.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
During spin cycle, washing machine is bouncing around the room
Sounds like the drum, balance weights have come off, to me. This will cause those symptoms.
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
SHAKING WASHER
I had a shakey washer that I bought open box from "circuit city", it was a return.
I was to lazy to learn why the washer would shake and a technician told me to manually balance the wash load in the drum.
Later, I got into the washer and lubed up the rotating shafts and rockers. The washer lost all its shakes with the mechanics properly lubed. From the factory the mechanics were never properly lubed.
Tight mechanics that are supposed balance the spin cycle by moving could be part of what is getting warm. The belt spinning the washer also takes a beating when the drum shakes.
Get a good discount on your washer first, and then lube the mechanics. Everything about the washer is meant to work. If the mechanics are too tight you'll have shaking.
Jan 25, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Shaking washing machine
If the shaking is during the spin cycle and you are using the High setting change it to Medium. This may fix the problem and the clothes will probably come out even dryer since the drum is not banging around.
Sep 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9300PW4 vibration problem. We have vibration pads already under the feet. We have the machine level with 3/4'' plywood bolted to the subflooring. The vibration was better for a while and...
If you dryer moves away from the washer when the washer is shaking then it's still your floor sorry. The duets are not really known to have bad vibration and shaking problems. If you think the floor is ok then check to see if your inner tub basket can wiggle up or down their should be no play in the basket, you could have a bad tub bearing, make sure your drain pump is pumping out the water fast enough. hope this helps.
Feb 22, 2009 | Whirlpool Washing Machines
Whirlpool duet washing machine
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Good luck!
Aug 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
