Power cord overheats - Computers & Internet
    Guru:
  • 689 Answers
Oh no! nasty one,,switch it off throw it away get correct equipment for your machine--this is a dangerous unspecified problem that could end in tragedy --its not an IBM is it?
Posted on Sep 05, 2010
I can turn the welder on and it can run all day but when I start welding with in a minute the overheat light will come on and it will stop feading wire. I'm trying to weld on mid temperature.
Have you checked so see if your power cable is the right size?? Is it a 220 or 110? If it is 110 then it will cut off after it gets hot, if it is 220 and the power cord is too small then the machine will be trying to pull more amps than the cord can handle causing it to overheat and shut off.. My husband has been a welder for 20 years.. I'm just passing along what he suggested might be the problem.. Hope this helps!
Oct 03, 2015 | Millermatic 212 907405 Auto-Set Mig Welder...
What my air compressor easily overheat and stop operating?
try connecting it directly into a wall outlet without extension cord. overheating may indicate a bad motor, bearings, or starving for power, power is lost in extension cords that are not large wire gage enough.
Mar 14, 2015 | Air Tools & Compressors
Frigidaire FRA 155MT1 melted the extension cord and surge protector
You must use a heavy duty power cord with this unit as it draws alot of amerage. Most regular extension cords csnnot handle the amperage and overheat or melt.
Jul 07, 2012 | Frigidaire 15,100 BTU Heavy Duty Window...
The thermostat is not shutting the unit down and cycling it on/off as it should. This will cause the power cord to overheat and it will catch fire. STOP using this unit and either replace it or have it repaired. More than likely cheaper to just replace it.
May 30, 2010 | Krups FLF2 Cordless Electric Kettle
Cord gets hot when both 1500 is used
that is a sign of overloading. it could also be from undervoltage. does the plug fit solidly in the recepticle or is it rather loose?this could also cause the power cord to overheat.
Jan 11, 2010 | Heating & Cooling
Was out of town had power surges not tv doesn't work.
If cord does not light, then power supply is fried. It is common. The capacitors overheat and burn out. I recommend using surge protector on any expensive electronical device.
Nov 12, 2009 | Televison & Video
Hello heres my problem the power cord tip gets so hot and burns even ive replaced the battery ive replaced the cord and the tip and its stil happening help please
Seems that your notebook's power socket, where you plug the power cord, is damaged & is causing a loose connection. The loose connection causes the power socket as well as the power cord's tip to overheat & burn.
Oct 30, 2009 | Compaq Presario M2000 Notebook
Nobilis laptop overheat?
Nobilis Has HEAPS OF PROBLEMS! take it to an expert computer shop and they will fix it.
Apr 21, 2009 | Computers & Internet
Dryer Cord melted....
The power cord overheats and melts due to a failing power cord receptacle (the contacts loosen over time). To correct this problem, the receptacle and power cord should be replaced.
Jun 18, 2008 | Dryers
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
