Question about Sony KP-53XBR45 53" Rear Projection Television
Sony KP-53XBR45 53
The "Standby/Timer" light on front panel will blink once or twice and then it shuts off by itself every time i try to power it up. I push the power button then I hear a couple of clicks the lights blink and then nothing. Please could you help me?
  • Christine102 Jun 10, 2008
    I have the same problem do you know if it is worth fixing thanks
    Master:
  • 479 Answers
Its the problem of capacitors and --ics-- on the main power supply board , as some of them are blown off or bulged and not supporting the board to get the tv ON .
how the board looks and how the components on it looks and how to replace them is given in the above link .but keep in mind the pictures given in the above link will exactly not match your board but will give you the rough idea about how to do and what to replace.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
also for more help you can read this link in it there are few questions asked with the same problem what you r facing just read the question answers as there are many solutions so this will also help you
please click the link
http://www.anatekcorp.com/faq/archprotv.htm
and finally before all this solution please try the following suggestion.
I recomend to disconnect all the board one by one and clean all the connectors. RSC.
Posted on Sep 24, 2008
No picture or sound. standby light on front panel
The light is blinking a repeating error code. Try to determine the number of blinks before a slight pause as that will be an error code. Then respond to this same post and I will assist you with diagnosing what may be causing the set not to power up.
Dec 11, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony KP-57WS500 Rear Projection TV Problem
hello if you could tell me how many times it blinks i'll try and tell you the fault thanks
shaun
Oct 25, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51WS520 won't turn on
Something bad in power supply or horiz output.Possible bad gun.Needs a repair shop unless you know electronics.
Jul 07, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
KP-51WS520 wont turn on - standby & timer lights on constantlly
You need to check supply volts on main micro IC702 on main board of Sony KP-51WS520 TV.
If you have experience of big TV repair then I would recommend to get service manual of TV from any online store and check above said IC supply volts. TV must give error by blinking light in case any problem in drive circuits and if main micro fried, no error signal will be there.
Dec 05, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony KP-51WS510, standby led blinks 5 times
It sound like you have a bad picture tube...check your 1k circuit for correct voltage and wave form.
Oct 03, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS510 Shuts itself off
eight blinks means, "High-voltage error" and the probable cause location listed is, "T8005 is faulty (D board)". T8005 is the fly-back transformer assembly.
Dec 09, 2007 | Sony KP-51WS510 51" Rear Projection...
Televison & Video Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
