Question about Karcher PSI Electric Pressure Washer
Karcher k3.68m leaks from the pump area. If I turn it on without holding the trigger down on the wand it will not blow pressurized water. If the motor is idle and the water is turned on then it leaks a lot from the pump area. What part should I replace?
4 Suggested Answers
  • 104 Answers
SOURCE: Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Posted on Jun 05, 2009
  • 12 Answers
SOURCE: I have a karcher 2400 psi pressure washer and it
the most comon problem with thease is a stuck bypass valve, this is the valve that alowes the water to bypass round the pump when the triger is closed, when they stick all of your pressure runs around the pump and not out of your nozzle,,
its located in the centre of the pump on the top, undo the 2 cap screws pull out valve greese and re fit
Posted on Jun 18, 2009
  • 5 Answers
SOURCE: karcher pressure washer trigger problem
The wands that it will not run with would most likley have a little dirt in the tip of the nozzle. This would not allow the water to flow through in turn activating the pressure switch and shutting the machine down
Troy
Posted on Jul 08, 2009
My Karcher 530M runs ok until I release the trigger, then it will not start again unless I switch and allow the water to run through for about 15 secs before switching on again
Hi Cliff:
My experience is that the pump pressures prevent the engine from starting, so we hold the trigger while starting.
My brother has cut a wedge of wood that he uses to jam the trigger open to bypass the problem. It can get a bit wild if the wand is not secured when the unit is started..
Aug 10, 2016 | Karcher Garden
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
Let go of wand trigger pressure will not come back
spill valve is stuck and needs to be cleaned and greased common problem....also check all connections for blockage in line
Jul 21, 2010 | Karcher 2500 PSI Pressure Washer
Karcher k1 leaking from inside casing.
The most likely issue, which seems to occur alot with karcher, is a cracked water pump. What happens is that as you release the trigger on the handle, the rise in pressure should cut off the motor, but as it also cuts off the water flow at the wand end and the motor spins a few more revs until it stops, then there is a huge pressure glitch which blows apart the weak plastic pumps that they use. Since the plastic cracks it is very difficult to repair and the only option is to go and buy another. BUT...this time tape up the trigger on the handle so it is always on and then it won't blow itself up. Just use the unit on/off switch to turn the motor on and off.
Apr 11, 2010 | Karcher Garden
My Troy Built pressure washer shuts down when I turn on the water. Is the pressure cut off valve that might be frozen?
Hold the trigger of the pressure nozzle open. Turn on the water . Wait to see water coming out of the pressure wand.Then try and start the engine. They can get air locked.
Feb 12, 2010 | Karcher 2500 PSI Pressure Washer
Honda 2400 psi before it went out i cold tap the end of the wand on the ground and the pressure would return now when pull the trigger there is no pressure only a fine spray .its a karcher with a honda...
hi,
there is a small ball bearing inside the nozzle on the end of the lance , this can get jammed or missaligned and the nozzle orifice can get blocked , clean this or replace the whole lance with another 200 Bar lance .
hope this helps
Feb 01, 2010 | Honda Karcher G2400HH-R Pressure Washer
Karcher pressure washer trigger problem
Troy
Jul 05, 2009 | Karcher K2.26 Electric Power Washer
Jun 04, 2009 | Karcher PSI Electric Pressure Washer
Karcher 2400 psi blaster When you release the trigger it will not pick up pressure when you use it again
To determine if your problem is due to an easily replaceable part, follow these steps:
1. Connect the water supply hose, the pressure hose, and the wand WITHOUT any nozzle tip.
2. Turn on the water supply, and press the trigger until water is smoothly running out of the nozzle
after any air is all purged out. Release the nozzle trigger.
3. Start the engine, and let it warm up for about 30 seconds.
4. With the engine running smoothly, press the nozzle trigger. The water should flow out of the nozzle (without the tip installed) at a faster rate, while the engine noticeably loads down as it used to do before your "no pressure" problem. If it does not load down, turn it OFF, and disconnect everything, and contact a Karcher repair facility.
5. If the engine does load down, release the trigger, and install one of the nozzle tips (not the black one).
6. Press the trigger, and the engine should load down, and you should have normal pressure from the wand. After you release the trigger and press it again, you will probably again have no pressure, and the engine will not load down. Removing the nozzle tip, pressing & releasing the trigger, and re-installing the tip should give you normal pressure again, but releasing the trigger will cause no pressure until you again remove the tip, press the trigger, and re-install the tip.
This is caused by a bad UNLOADER VALVE, which is located under a black cap with a metal button on it located on the top front of the pump. I don't know if you can purchase the replaceable parts from a Karcher repair shop, but when a neighbor & I took his washer to a repair place, it looked pretty simple to do this repair, and he was charged about $60 to replace a $5 (maybe) part, and it took about 5 minutes.
Sep 12, 2008 | Karcher 2500 PSI Pressure Washer
There is no pressure
This is caused by a bad UNLOADER VALVE, which is located under a black cap with a metal button on it located on the top front of the pump. I don't know if you can purchase the replaceable parts from a Karcher repair shop, but when a neighbor & I took his washer to a repair place, it looked pretty simple to do this repair, and he was charged about $60 to replace about a $5 (maybe) part, and it took about 5 minutes.
Sep 11, 2008 | Karcher 2500 PSI Pressure Washer
Karcher PSI Electric Pressure Washer Logo
187 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
