Question about Intuit QuickBooks Pro 2002 (260102) for PC
I cannot get on my program. It says "A problem caused the program to stop working". From there, all I can do is click "close program". Can you help me?
    President:
  • 3,278 Answers
Hello.
If you have restarted your computer and tried several times with the same results, the only solution is to reinstall Quickbooks Pro.
Go to Control Panel - Add / Remove Programs (or Programs and Features) and remove the QuickBooks software.
With the QuickBooks CD (or if you downloaded the program, run install from the place you downloaded), run and install the program.
Hope this helps.
Posted on Sep 05, 2010
Crystal eye webcam stopped working
click startt right click on computer select properties device manager scroll to image devices if you se a yellow question or exclamation or a red X the driver will need to be updated right click to update driver
hope this helps
Aug 06, 2012 | Computers & Internet
Everytime i open my Yahoo msil, i get an error message that says that the website has caused the internet to stop working, close program? So i click close, and it closes and immediately restores and does...
Try installing a different browser like FireFox or Google Chrome. See if they work.
Could be an indication of a virus, is you anti-virus working and up-to-date?
Best of luck, Jim
May 01, 2011 | Computers & Internet
I have installed lg pc suite II and everything connects fine. but when i click on anything to use, eg Phonebook etc on the computer and window pops up saying: MobileSyncLauncher MFC (and then some odd...
you should reinstall the program .Some times first install become damage due to problem in registry editing . I hope reinstall will solve your problem.Thank you
Aug 08, 2010 | Computers & Internet
I have a gateway computer running windows vista with a gateway multimedia keyboard. When i log into the computer a message pops up that says "multimedia keyboard driver has stopped working. A problem...
goto start right click on my computer click manage click device manager. on the right of computer management screen click keyboard right click the device and uninstall. restart your computer
Jun 30, 2010 | Computers & Internet
A problem caused theprogram to stop working correctly. Windows wi
Your problem is a little hard to say. Have there been any power outtages or has you computer been powered-off rather than the regular shut-down procedure. Windows registry and programs can be thus corrupted.
Also computer viruses can disrupt programs so please run for example
Mcafee's free online anti-virus to rule-out a virus problem.
http://us.mcafee.com/root/campaign.asp?cid=45694
Even if you have an anti-virus installed, it needs to be running the latest virus definitions.
You could also try in programs accesories system tools to select "system restore" and bring back your computer to a date where you understand the problem was not happening. (Try this one last)
Jul 11, 2009 | Computers & Internet
Yahoo messenger has stopped working
I have gotten this issue several times being a tech for the HP notebook division and I found a simple solution for it.
Right Click on the Yahoo! Messenger icon on the desktop and select properties.
Click on the Compatibility Mode tab
Check the box at the top to enable it and make sure the mode is Windows XP SP2.
Select ok.
Restart machine.
I hope this works for you all. =)
Oct 23, 2008 | Yahoo Messenger
Windows dvd maker
What OS are you using? Ultimate, Premium, Basic?
Windows DVD Maker has stopped working Issue : While trying to create DVD in Windows DVD Maker in Vista, or while creating a DVD from Windows Movie Maker, which uses Windows DVD Maker, the burn process stops with error message.
Error message : " Windows DVD Maker has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "
Cause : Windows DVD maker stops working because of incompatibility with one or more codec files which are outdated or incompatible with the particular project or the DVD Maker software itself.
Resolution :
These Codec files should be located and renamed to resolve the issue.
1. Open Start menu and type Event Viewer in the Start menu search bar. Open Event Viewer from the menu.
2. In the Event Viewer window Click on Windows Logs in the left panel
3. Click on Application Logs under Windows Logs
4. Locate error messages listed in the Central panel of the Event Viewer window and double click the error to check if this is log is related to DVD Maker.
Sample Error Log :
Problem signature
Problem Event Name: APPCRASH
Application Name: DVDMaker.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549b5b0
Fault Module Name: nevideohd.ax
Fault Module Version: 4.6.15.0
Fault Module Timestamp: 459bb828
Exception Code: c0000005
Exception Offset: 00008b89
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1062
5. Locate Fault Module name, it should be a file with extension .ax.
6. Once the file name is identified, try to locate the file in C:/Windows/System32 folder. ( Please click on Show Contents if the files are not listed Automatically ).
7. If the files are not listed in System32 folder, search for the file, with search containing system files and folders.
8. Locate the file and rename it.
9. Check if the issue persists. If the issue persists and the error message again appears, locate the new .ax file that is causing the issue from the Event Viewer, error log.
These steps will resolve the issue instantly without a restart.
Sep 18, 2008 | Computers & Internet
Aspire 5610-2762 Orbicam not working
plz try by reloading the webcam software if you have webcam
May 27, 2008 | Acer Aspire 5610-4648 Notebook
Hi uninstall the Cam application software from add/remove programs and reinstall the same .
May 06, 2008 | Acer Aspire 5050-3242 Notebook
Intuit QuickBooks Pro 2002 (260102) for PC Logo
54 people viewed this question
Top Intuit Computers & Internet Experts
Scott Fair
Scott Fair
Dan Shibata
Dan Shibata
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
