Reset the router to factory default, this way you can put in a new password and WEP.
**On the vast majority of routers the reset button is found either on the back plate or on the underside of the router.
The reset button is on the rear of your router
**The reset button is YES! a TINY tiny little hole no bigger than a pencil point or full stop. You can easily miss it, to perform a reset you will need a paper clip or pin.
TO RESET, using the paper clip straightened out, push the end of the paper clip into the tiny hole, and push it firmly until you feel a resistance. hold the paper clip, & push & hold in the reset button for 20 -25 seconds (with the power turned on). after you have done this power off and power back on the router.
Now! the router should have all its original factory default settings, as if you just took it out of the box for the first time:so you should be able to get to the setup page and set the WEP encryption.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at
https://www.6ya.com/expert/joe_8b8c2cd6ce148309
