Question about NetGear RangeMax WPN824 Wireless Router
I need the security key or passphrase. - NetGear RangeMax WPN824 Wireless Router
  • 11,800 Answers
There is no default password (of course except the factory one -login=admin, pass=password). If you have forgot it then reset the router and set a new one.
Posted on Sep 05, 2010
Trying to secure wireless network
Welcome to Fixya. If you want to secure the network you all you need to do is to access the router settings page and put a security either WEP, WPA or WPA2 and a Network Key or Passphrase.
To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.2.1, the Default password is blank
Click on Security under Wireless, Select WEP, WPA or WPA2 and personalize a Security Key or Network Key (Passphrase). Security Key serves as a password on the network.
If you have questions please let me know. Thanks for using Fixya.
Mar 25, 2011 | Belkin (F5D7633UK4A) Wireless Router
Cant find wep key
Your printer is saying that you should secure your wireless internet. Try resetting the router by holding the reset button located on the back for at least 30 seconds.
Nov 20, 2009 | Linksys WRT160N Wireless Router
After installing the router it was working fine. I went in to set up wireless security and now the internet light stays red.
Probably means that the security is turned on, if the wireless doesn't work even after you have entered the right password then press and hold the reset button on the back of the router to restore it to defaults - factory defaults just like it was first powered on.
Oct 07, 2009 | Zoom X6 Adsl Modem/router Rohs...
Security key needed
the key was assigned by you when you picked the security type on your router during setup. The router is WEP or WPA , both require a Passphrase. Maybe you can get the ip address and type it in windows URL and see the setup instruction. Bottom line you need to get to the routers setup ...the passphrase will be shown on the security page. Good luck and be safe!
Please rate!
Mar 12, 2009 | Televison & Video
Need a security key or passphrase
Access the setup page of your router using a computer that is wired connected to it. Then go to wireless settings, there you will find the wireless security(security key or passphrase) enabled in your wireless network.
Nov 04, 2008 | Computers & Internet
How do I copy the security key?
the solution to this one is you need to reconfigure the router. you need to disable the security settings for your router. (WEP or WPA) then try to put in a new SSID and new security key. that's the only way that you can get a new security/passphrase key for your network. for further assistance you need to contact the router manufacturer for router configuration.
i hope this helps.
Sep 13, 2008 | Computers & Internet
Wireless connection
Hi mitch46,
The security key or passphrase can be generated by your router. If you go into your router by typing 192.168.1.1 and click ontot he wireless link or tap and it will give you options to generate security key.
Hope this helps and good luck.
Jul 20, 2008 | Computers & Internet
Security Keys or Passphrase
  1. Now we will secure you wireless connection to prevent others from connecting. Under the Home tab, click the Wireless option from the left.
  2. Beside the SSID option, enter the name for your wireless network connection.
  3. Beside Security, select WPA. If you can’t connect using WPA, then select WEP. Using WPA will provide a much more secure connection that using WEP. For more information about WEP and WPA please read Wireless Security: WEP and WPA.
  4. Click AES beside the Cypher Type.
  5. Make sure PSK is selected beside PSK/EAP.
  6. Now you must get very creative. Specify a long Passphrase with a mix of upper and lower case letters, numbers and punctuation. Once again, please read Creating Secure Passwords for tips on how to do this. In this case the longer the better. Make sure you write down this key somewhere, either on a piece of paper or in a text document on your computer. You will need this information when you connect to your wireless network.
  7. Enter your passphrase next to Passphrase and again beside Confirmed Passphrase.
  8. Click Apply to save your security settings.
  9. Now you are all done securing your wireless router and network. All you need to do is connect to your network, and enter your Passphrase exactly as you specified it. I won’t go into detail on how to connect to your wireless network, as I will save that for another post.
May 10, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Having trouble adding computer to wireless network
this is just easy.. what you should type is the encryption key only... if your security is wep, only the encryption key or key 1 is needed. if your security is wpa, only the passphrase is needed.. it is very CASE SENSITIVE.. but if you see that the name has changed to LINKYS_SES, then you have a problem there because your wireless settings has changed due to the button on your router which is the secure easy set-up on the upper left corner which is the cisco button.
Feb 21, 2008 | Linksys Wireless-G WRT54GS Router...
Procedure to secure wep
Routers can be secured in two common manners.
First the network access as you have started using WEP which I will discuss more later.
Second by assigning an administrator password. This prevents anyone except a person possessing the password from configuring your router. This is good to do however if you forget the password resetting the router will clear all of your configuration -- so keep notes to reconfigure your router in a secure place before assigning this password.
Now as to WEP encryption -- first it is preferred your network name (SSID) be unique in your area hopefully you have already changed that. Second WEP generally requires the entry of a passphrase that causes the generation of 4 keys and in a separate box the selection of one of those 4 keys as active. Wireless adapters I have seen either accept a passphrase and active key number like the router or they require the specific active key value from the router. Keys contain hex values characters 0-9 and A-F and are not identical to the alphanumeric passphrase that was entered. Entering the appropriate value into the adapter is required for successful connection.
Security is achieved on the network not by entering the "password" every time you connect to the network but by storing the passphrase (password) and/or the generated by-products in both the computer and router in advance. Since no unauthorized persons know the passphrase or password the access on the wireless is secured. Changing the passphrase periodically is not a bad idea to maintain the security of the network (must be changed in both the router and the device with a wireless adapter. Loss of a computer means loss of the control of the passphrase and should result in a change of the passphrase too.
If you have any additional questions please respond to this with an additional comment.
Dec 31, 2007 | Dell TrueMobile 1184 Wireless Broadband...
NetGear RangeMax WPN824  Wireless Router Logo
35 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
